I have this skin on RPI2 /kodi 15.2 (changed to 14.1 to continue testing samething?). I have noticed that if I have Conflence as the skin, Pandora loads without an issue, but when I switch to Re-Touched or CarPCTouch (Since I have Raspberry Pi Official touchscreen 7") pandora script fails to load (on the login prompt).
Any pointers?
is it the Pandora script or the skin?
(2016-01-23, 02:25)ronie Wrote: [ -> ]could you post a Debug Log?
here is the log requested ( I think)
NOTE---->>>>19:02:07 T:1829762112 ERROR: EXCEPTION: XML File for Window is missing
19:02:07 T:1829762112 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.RuntimeError'>
Error Contents: XML File for Window is missing
File "/home/pi/.kodi/addons/script.audio.pandora/default.py", line 291, in <module>
panda = Panda()
File "/home/pi/.kodi/addons/script.audio.pandora/default.py", line 129, in __init__
self.gui = PandaGUI( "script-pandora.xml", _path, self.skinName )
RuntimeError: XML File for Window is missing
This is in confulence skin
/home/pi/.kodi/addons/script.audio.pandora/default.py): instantiating addon using automatically obtained id of "script.audio.pandora" dependent on version 2.1.0 of the xbmc.python api
20:20:20 T:1812984896 NOTICE: Pandora: Initializing v2.3.2
20:20:20 T:1812984896 NOTICE: Pandora: sys.platform = linux2
20:20:20 T:1812984896 DEBUG: DialogProgress::StartModal called
20:20:20 T:1812984896 DEBUG: ------ Window Init (DialogProgress.xml) ------
20:20:20 T:1812984896 INFO: Loading skin file: DialogProgress.xml, load type: KEEP_IN_MEMORY
20:20:20 T:1812984896 DEBUG: DialogProgress::StartModal called (already running)!
20:20:23 T:1966944256 DEBUG: ------ Window Init (/home/pi/.kodi/addons/script.audio.pandora/resources/skins/Default/720p/script-pandora.xml) ------
20:20:23 T:1966944256 INFO: Loading skin file: /home/pi/.kodi/addons/script.audio.pandora/resources/skins/Default/720p/script-pandora.xml, load type: LOAD_ON_GUI_INIT
20:20:23 T:1966944256 DEBUG: CGUIMediaWindow::GetDirectory ()
20:20:23 T:1966944256 DEBUG: ParentPath = []
20:20:23 T:1812984896 NOTICE: Pandora: Window Initalized
20:20:23 T:1812984896 DEBUG: DialogProgress::StartModal called (already running)!
20:20:23 T:1812984896 DEBUG: ------ Window Init (DialogProgress.xml) ------
thanx, looks like the addon is searching for a script-pandora.xml file in re-touched.
there's no such file here in re-touched.
if the pandora addon needs that file, it has to provide it itself.
you're better off reporting this issue to the addon dev.
(2016-01-24, 03:34)ronie Wrote: [ -> ]thanx, looks like the addon is searching for a script-pandora.xml file in re-touched.
So it exists in confulence skin? can I just copy it over?
