Full Version: Hybrid skin textures (plead for help)
Please can somebody help me as I have made a build for my son, I have used hybrid skin but have modded it a bit. I have used the texture packer tool and decompiled the textures and colored them in using GIMP and then I have compiled them back into the kodi skin media file where I originally took them from. The problem is now I have finished the build I can no longer put any urls in file manager to install any addons. I have alse tried putting the unpacked textures back into the folder without compiling them and that also does not work. Any help would be greatly appreciated as I havwnt got any addons in it yet.
Many thanks,
Lynn
Are you sure you haven't changed any skin code as the textures can't be the problem?
I also tried it on a fresh install and just transfered a couple of pictures over without changing any code and that also didn't work so I think it's actually the skin itself that's the issue. I then tried it on hybrid Dev and looks to be working.
