I am unable to get Yahoo weather to show anything other than the current day. I did also try Openweathermapextended and although this did show all the days the results were ridiculously incorrect, but were actually the same results I got on their website. Is it possible to use another service or fix the Yahoo? I am located in Spain.
Use Weather Wunderground, but you need get API Key for work fine.
Will I get a different forecasts with the API key then? Only I went on their website and checked my weather there and it told me it was going to rain for the next 7 days and be 8 degress, but I am in southern Spain so no chance! I will give it a go though and see what happens.
Ok I got an API and entered it and the forecast now says its going to snow here on Monday and be 1 degree lol. How does this API work then does it read my IP location?
Alhaurin de la Torre, Malaga, Spain. Tried it three times now with API key and it tells me tonight is 16 degrees, which is probably correct, but the next 7 days forecast is complete tosh saying 1 degree and snow for Monday.
Personally I think the Openweathermap data is seriously flawed for this location even their website is giving complete nonsense. I would really like to get the Yahoo service working if possible.
Test your city here, with openweather..compare
OpenWeather:
Weather Wunderground:
Don't know how you put images on here but this site has more realistic weather, 8 degress no chance here.
http://www.foreca.com/Spain/Alhaurin_de_la_Torre?tenday
10 day forecast
Today
Hi: +22°
Lo: +17°
W 13 kmh
Details
Tomorrow
Hi: +21°
Lo: +15°
NW 13 kmh
Details
Sat Feb 13
Hi: +21°
Lo: +16°
W 14 kmh
Details
Sun Feb 14
Hi: +19°
Lo: +13°
NW 28 kmh
Details
Mon Feb 15
Hi: +16°
Lo: +9°
NW 31 kmh
Details
Tue Feb 16
Hi: +15°
Lo: +9°
N 24 kmh
Details
Wed Feb 17
Hi: +16°
Lo: +4°
NW 18 kmh
Details
Thu Feb 18
Hi: +16°
Lo: +7°
E 15 kmh
Details
Fri Feb 19
Hi: +17°
Lo: +8°
E 15 kmh
Details
Sat Feb 20
Hi: +18°
Lo: +8°
N 18 kmh
Sorry I didnt read your original post correctly I thought you was talking about Openweathermap and just realised you posted two different the 2nd is weather wunderground and that is giving good results but how can I get that on MQ6?
Only need install addon and configure. Go to website Weather Wunderground, register and get personal api key for work.
To get a free API key:
please sign-up here:
http://www.wunderground.com/weather/api/d/login.html
click on the activation link in the confirmation email
log in to your account
go to:
select 'Explore my options'
on the next page, select 'Anvil Plan' and click 'Purchase Key'
fill in the registration form (doesn't really mater what info you supply here)
on the next page, find your 'Key ID'
enter the key in the addon settings
Sorry this may be a stupid question but how do I get the addon? I go to weather, service for weather information, and get more, and its not listed. I also tried installing from a zip I found somewhere but it just says dependencies not met and won't install.
(2016-02-12, 00:53)Wanilton Wrote: [ -> ]For Kodi Jarvis direct repository official Kodi
http://mirrors.xbmc.org/addons/jarvis/we...derground/
I decided to upgrade to Jarvis and now the weather underground works with extended forecast but I get no icons ie sun clouds etc is that normal? On extended I just get the heading of the day and date then a big gap to the temperatures, it looks as if there should be something in between. Also a bit confused by the name, I installed weather underground from the available services but the website is weather wunderground, are these the same thing the zip appears to be the same? I have installed the extrapack thinking that would give me more weather detail but it don't seem to make any difference.
