2016-02-15, 11:08
Hello all,
I'm trying to make Kodi play DVD disk from drive which is shared over the network using nbd server and client.
NBD server is configured at the Linux PC with DVD Drive running Debian.
NBD client is configured on Raspberri Pi 2. I can Mount that drive on Raspberry and can see its content. If I then add the directory what the nbd device is mounted to to video files as location and click play, it is not working well. I have tried 3 different disks, :
1/ One disk was played and I could navigate thru it using previous/next keys. It has no menu.
2/ Another disk (Red Dwarf) started the main menu animation and then went back to Kodi GUI. In order to try it again, I had to connect once again to the nbd-server and mount the drive on Raspberry, because the connection had dropped for some reason. But it never played more then a few seconds of menu.
3/ Another disk. When I hit play, it just showed black screen and looked like its just about to play, but then it went back to Kodi gui.
Another issues I haven't solved yet are:
a/ I have to connect to the client and mount the drive manually. I could add the client connecting command to some autostart script, but it fails if theres no disk in the drive.
b/ Once I connect form the client, the drive is locked and cannot be opened. I have to restart the server part of nbd if I want to open the drive.
Has anyone suceeded in configuring shared optical drive so it works smoothly and can be controlled in a "BFU friendly" way?
Thanks a lot!
Thanks a lot!
