Assuming this is not possible, searched pretty good for it. I have been a Tivo junkie since 1999, cut the cable a LONG time ago. Would love to access my Tivo recordings via Kodi, is this possible? I know encryption is a huge issue obviously....thx...Scott
There was a Tivo file decoder one upon s time.
Its very easy the encryption is not a problem you are legally allowed to decode it for your own use. Its part of your subscription called Tivotogo
Look in your tivo info page and it will give you the password to decode the files. Its called the media key.
Go download and install the software called kmttg on your pc.
https://sourceforge.net/projects/kmttg/
You can then download all your shows convert them to standard mpeg 2 files. You can then move the files to KODI. I run a ftp server on my pc so I can move files over.
What we need is KODI plugin to duplicate what kmttg is doing.
They use a opensource decoder located here
http://tivodecode.sourceforge.net/
The files are very easy to download to to the ip address of your tivo using
https://192.168.0.x enter tivo as username and media key as password.
You can even add this url to kodi and let it scrap all the files but they would need to be decoded after downloading
Does the above program actually RE-ENCODE the tivo files or does it losslessly to MPEG2?
(2016-12-07, 02:23)TheLastOfUs Wrote: [ -> ]Does the above program actually RE-ENCODE the tivo files or does it losslessly to MPEG2?
It will pull it over in the same type as it is on the tivo - you can also have it re-encode the file using ffmpeg
