Full Version: Can only install V17 Alpha
Pages: 1 2
I've tried to install Kodi 15 or 16 on linux mint 17.3 but it always installs V17.0 alpha.
sudo add-apt-repository ppa:team-xbmc/ppa
sudo apt-get update
sudo apt-get remove kodi kodi-bin
sudo apt-get install kodi
V17 again again
sudo apt-get purge kodi
sudo apt-get update
V17 alpha again
Please,how/where do I get a stable V16.0?
What is the output of
apt-cache policy kodi
kodi:
Installed: 2:17.0~git20160327.0300-bc0c579-0trusty
Candidate: 2:17.0~git20160328.0200-2d05a88-0trusty
Version table:
2:17.0~git20160328.0200-2d05a88-0trusty 0
500 http://ppa.launchpad.net/team-xbmc/xbmc-nightly/ubuntu/ trusty/main i386 Packages
*** 2:17.0~git20160327.0300-bc0c579-0trusty 0
100 /var/lib/dpkg/status
2:16.0~git20160220.1654-final-0trusty 0
500 http://ppa.launchpad.net/team-xbmc/ppa/ubuntu/ trusty/main i386 Packages
You have the nightly ppa installed ... remove it and downgrade to v16.
The sites say v16.0. I'll look up downgrade but why can't I find v16?
Is v16 not available for linux?
It is - you even see it listed above .. but you broke your package management system ... and now need to manually downgrade.
Hi,found this
1.1.4 Downgrading to a stable version from a development version
If you install a nightly build or an unstable release and want to return to a stable release, follow these instructions:
Find the current PPA you are using:
sudo apt-cache policy | grep team-xbmc
Remove the unstable or nightly PPA where it says PPAHERE:
sudo add-apt-repository -r ppaTonguePAHERE
Then restore the stable version with the following commands:
sudo apt-get update
Please, what do I put in PPAHERE: ? sudo apt-cache policy | grep team-xbmc shows
500 http://ppa.launchpad.net/team-xbmc/xbmc-nightly/ubuntu/ trusty/main Translation-en
release v=14.04,o=LP-PPA-team-xbmc-xbmc-nightly,a=trusty,n=trusty,l=XBMC Nightly Builds,c=main
500 http://ppa.launchpad.net/team-xbmc/ppa/ubuntu/ trusty/main Translation-en
release v=14.04,o=LP-PPA-team-xbmc,a=trusty,n=trusty,l=Kodi stable,c=main
I have done this before when testing new versions of Kodi and rolling my setup back to the previous stable version of Kodi.
Note:
It is recommended that you backup your Kodi user settings just in case. Here is the
relevant page in the Kodi Wiki:
http://kodi.wiki/view/Backup
Fixing up the Kodi PPAs (remove unstable and nightly and add the stable PPA):
Open up a terminal and type in the following
sudo add-apt-repository -r ppa:team-xbmc/xbmc-nightly
Press the y key and ENTER to remove the PPA.
sudo add-apt-repository -r ppa:team-xbmc/unstable
sudo add-apt-repository -r ppa:team-xbmc/ppa
Now add the stable Kodi PPA:
Press the y key and ENTER to add the PPA.
Update your computer software sources lists:
sudo apt-get update
Next, remove your current version of Kodi:
sudo apt-get remove kodi*
Install the stable version of Kodi:
If the installation stops because some packages are bieng held back/missing you may need to do a dist-upgrade
to download the missing components:
sudo apt-get dist-upgrade
Then try to install Kodi again:
Thanks for the reply. I got this.I'll delete Kodi and try,try,try again Smile
elnasty@elnasty-MT6223B ~ $ sudo add-apt-repository -r ppa:team-xbmc/xbmc-nightly
[sudo] password for elnasty:
Usage: add-apt-repository [options] repository
add-apt-repository: error: no such option: -r
Your apt-add-repository is old - it does not have that opion.
Remove the relevant file manually from /etc/apt/sources.list.d/ directory - it's the one that contains the xbmc-nightly.
Thank you fritsch. I should stick to windows because I can't even delete a file...
chmod: changing permissions of ‘/etc/apt/sources.list.d/team-xbmc-xbmc-nightly-trusty.list’: Operation not permitted
Thanks everyone. Kodi on my android phone,2 windows puters and 2 pi2 and 1 pi3 was easy.
I'm too old to learn linux Sad
well....maybe you have to be a bit more patient then Wink
removing a file is not done by chmod. It's done via rm:
rm /etc/apt/sources.list.d/team-xbmc-xbmc-nightly-trusty.list
check the folder if more than one file with xbmc-nightly is listed there and delete that, too.
Then follow the steps J876 told you
Put "sudo" in front of the rm or it won't work.
Thank you everyone. I now have Kodi v16 Jarvis and it plays vids on a usb stick fine.
If I had used sudo I probably would have deleted the file with rm but used chmod to make it read/write.
I'm 62...old dog,new tricks n all that. Ubuntu sent me a cd from Holland 10 years or more ago when it came out but I never got anywhere with it.
Thanks again...you've made a happy man old Smile
Pages: 1 2
