2016-04-07, 17:20
Since i bought a new Apple TV i'm hooked on the way it plays nicely with my home AV system.
I would really love to make KODI act the same.
At any time i push a button on the remote, the Apple TV checks if it is the active source. If it's not it will tell the TV to make it an active source. As soon as a button is pressed, the tv switched to the Apple TV.
If the TV (and other devices in the system) are powerd off, it will turn on the devices and make the Apple TV the active source.
This would eliminate the need for an extra remote or anything if you want to switch to KODI, Just take your remote you use with KODI and press a button. It will either turn on the system, or make it the active source.
