2016-04-08, 15:09
EDIT.. After looking through some other comments in the forum I can see that others are having the same problems and sub3 has a fix but at this stage it's not a part of the official repo yet. I can access the git repo but I'm running Windows, not Linux, and I have no idea how to make the new version of the plugin from the source code... if any kind soul out there would be able to help me out and host the file I would be very grateful!
EDIT #2... I tried MtMk's solution here and manually updated the plugin to 1.12.14, however I'm still having the same problems - seems like nothing has changed for me..
Hi there - just moved to NextPVR from WMC (now using HD Homerun Connect). I'm finding some quirky things when trying to record series within Kodi.
If I select to record a show in the guide, I don't get given the option to record the one show or a series (unlike when I used ServerWMC). It's only ever one show.
When viewing the timers, the type is listed as Child Recording in Kodi. It also shows as scheduled recording in NextPVR, however when I go into the show details in NextPVR, I can't change it from Record once.
If I go the other way, and schedule a recording from the NextPVR guide, I get a whole bunch of options:
Back in Kodi, It does reflect that selection (eg "Every Day from 1.00pm to 2.00pm") and it might say Repeating (guide) or Repeating (manual depending on which option I selected in NextPVR. However I can't seem to change the type within Kodi, and I certainly can't create one of these repeating timers in Kodi.
If I try and add a timer through the timers menu, all I get is:
..none of which is right for me.
I'm using Kodi 16.0 (confluence skin), NPVR 3.6.6, Next{vr Plugin 1.12.8
Any help is greatly appreciated!
- Record Once
- Record Season (New episodes on this channel)
- Record season (all episodes on this channel)
- Reason season (daily, this timeslot)
- Record season (weekly, this timeslot)
- Record season (monday-friday, this timeslot)
- Record season (weekends, this timeslot)
- Record All Episodes, All Channels
- Once time (manual)
- Repeating (manual)
- Repeating (keyword)
