Is there anyone that would like to create a script to download movies and TV shows from Joox.net?
The script should really rock if there was a 'download-list' and 'shutdown after finish downloading' function in it. But I guess that will be allways a dream.
Works perfect with a minor mod to py file
C-Quel Wrote:Works perfect with a minor mod to py file
do you mind posting your mod?
remove:
import Image, ImageFile
or just grab the kmlbrowser script and copy the lib folder to you system/python folder
What is the quality like for joox.net? what resolution and how well does the streaming work... e.g. pauses, skips, etc?
Seems like more and more of these types of sites are popping up, most suck and have lame or old stuff and/or very little of anything.
Joox uses stage6 from divx.com - and that is a high resolution alternative to youtube, they have a very good server and high resolution video content. I have seen stuff with almost DVD quality being streamed without a problem, if you have a fast enough connection that is.
Joox recently changed the layout for the new entries.
I think that the current script doesn't play this new entries.
The modification to make it work is pretty easy though.
tangomar Wrote:Joox recently changed the layout for the new entries.
Scripts working fine. The site is just down. Check out there facebook group for updates
http://www.facebook.com/group.php?gid=2371729225
Maybe the site will come back with some changes though... hope not.
which joox script are yall using?
i am not at my xbmc right now but i think it is 1.1 but I think it is working now as the site is backup.
It is sadly using a old database and new videos are not able to be added yet.
Admin said it should be up fully tomorow.
