This has probably already been asked. but Metropolis/Steampunk does not put a frame around album art in music, at least it doesn't on the two systems I use. Is there an easy fix?
TIA.
PS Not sure if it matters but I use UPNP for music.
In which view? Only Panel Square and Gallery Square are supposed to have frames around the album art.
I'm not sure this is the answer you are looking for but while I am browsing music my only view options are List and Low List.
The answer then is that apparently over UPnP that music isn't considered as part of your library and thus your only views available are List and Low List, which intentionally do not include frames around the artwork.
Oh well, it's not that big of a deal.
