I've been a user of SiO2 for a number of years due to the simplicity and speed along with the great looks. So much so I have it running on all 4 of my Raspberry Pi's.
I've just had to rebuild one of my Pi's and no matter where I look I can't find SiO2 anywhere. It's not in the official repo or Fastcolors own repo.
Any ideas Guys?
Thanks in advance
Unfortunately I skipped 16 and moved to 17 already, so in order to get the skin You must manually install from github zip file... I'll try to push it to my repo but unfortunately i've been working on "real life mode" and haven't had much time. Plus the submission part is time consuming.. and blah blah will not bother you with excuses. the only fact is Jarvis'Sio2 doesn't exist... there's ATV4 sio2 coming together and working... hope you can work with that.
https://github.com/fastcolors/skin.sio2/tree/ATV4
cheers.
(2016-04-28, 14:01)fastcolors Wrote: [ -> ]Unfortunately I skipped 16 and moved to 17 already, so in order to get the skin You must manually install from github zip file... I'll try to push it to my repo but unfortunately i've been working on "real life mode" and haven't had much time. Plus the submission part is time consuming.. and blah blah will not bother you with excuses. the only fact is Jarvis'Sio2 doesn't exist... there's ATV4 sio2 coming together and working... hope you can work with that.
cheers.
Awesome!
ATV4 works a treat. I've installed it on all 4 Pi's! Will this auto-update following subsequent releases?
Thanks for your continued efforts.
