Full Version: Problem with PlexBMC
Hey guys,
i followed all instructions and installed Plexbmc (would love to use it). There are no problems to change into the "Plex" View in the amber skin.
It is written on this site: http://kodi.wiki/view/Add-on:PleXBMC
"However, we recommend using a PleXBMC compatible skin for complete integration. Currently the two best supported PleXBMC-enabled skins are Amber and Arctic: Zephyr."
But i cannot find the Button "GO PLEX" or "PLEX" like in Amber. so i cannot get into the plex view :-(
Can somebody help?
I would love to use this skins.
Thanks for help in advance.
BEST REGARDS!
nobody can help :-( ?
Use PlexConnect instead.
Use PlexConnect It will fully integrate plex sources into the normal kodi library , allowing you to do anything you want
also you may need to go into skin settings after you use PlexConnect . and add links to the main menu
