2016-05-18, 22:42
2016-05-18, 22:42
2016-06-28, 08:37
Simple and cool
2016-06-28, 08:49
What is more it has plenty of USB ports to add more storage, although too many external drives would drive me barmy.
2016-07-12, 09:18
(2016-06-28, 08:37)MadsDK Wrote: [ -> ]Simple and cool
(2016-06-28, 08:49)nickr Wrote: [ -> ]What is more it has plenty of USB ports to add more storage, although too many external drives would drive me barmy.
6 and a eSata port. I am currently running 4 HDDs (2 x 1TB & 2 x 500GB). Soon I am going to upgrade it to Ubuntu 16.04 Server (bye bye GUI), change the boot drive to a 32GB SSD and upgrade the externals (I have a 2TB ready to go in).
2016-07-13, 19:10
HP Microserver you can buy for 150$ based on Low voltage AMD 15W
there you have 4 hotswap case for HDD and 2 more SATA (one for DVD one for 2,5 DISK) so is possible pack in that case 5 normal HDD and 1x 2,5
and you have also 2 PCIE slot which you can use example for DVB tuner and make TV streaming server also
2016-08-06, 10:28
(2016-08-06, 09:08)tubiel Wrote: [ -> ]SSD prefered with 3TB. Real speed.
Strange first post, but that's really wasted for media playback. Even very demanding 4K videos won't max out a 5400 RPM mechanical drive. It's like buying a sports car to only drive it at residential speeds (25 MPH in the US, but you get the point).
2016-08-06, 22:53
(2016-08-06, 10:28)Ned Scott Wrote: [ -> ](2016-08-06, 09:08)tubiel Wrote: [ -> ]SSD prefered with 3TB. Real speed.
This.^^^ The wife and daughter are watching two different 720p videos in two different rooms at the moment. The disk I/O on the server is current maxing at around 700Kbps.
2017-02-08, 16:16
The PSU went pop today. Luckily I had a spare. I have decided that the constant load of 4 external HDDs got the better of it. So I am finally going to add a new 2TB HDD, giving me 3TB for Movies (1x2TB & 1x1TB),1.5TB (1x1TB & 1x500GB) for TV Shows, 250GB for Music and the system drive is going to be a 32GB SSD. The 2TB drive and the 250GB drives are 3.5" with their own PSUs and the 2 1TB and the 500GB drives are 2.5" and will be powered by a USB hub. That and an internal SSD should reduce the load on the external PSU of the PC.
2017-02-09, 02:06
(2016-05-18, 22:42)speedwell68 Wrote: [ -> ]
An Acer Revo R3610 with 3TB of external storage. It has 4GB of ram with a 500GB internal HDD, which has my Music on it. The externals house the videos. Everything is shared with NFS and I have MySQL database too. It works really well and can serve up 1080p video to 6 Kodi boxes at once.
What OS are you using?
2017-02-09, 03:29
He says Ubuntu I think.
2017-02-09, 09:29
(2017-02-09, 02:06)SilverBlade Wrote: [ -> ](2016-05-18, 22:42)speedwell68 Wrote: [ -> ]
Xubuntu 16.04.1 X64. I went to Xubuntu because I run that on all my other machines and decided that it would be better to have a common UI to make it easier for the wife and kids to use should they be forced to. If you don't want a UI then Ubuntu Server would be the best choice. If it were just me then that is what I would run as I do everything over SSH. If you do want a UI then I have been playing with Bodhi Linux and Xubuntu Core, which are as about as minimal as they come, because ideally I would like to get a 16GB SSD to reduce costs.
2017-02-28, 22:56
I have just scored a 240GB SSD for free. I will replace the internal HDD with this, which will speed up boot times and reduce power consumption. I plan to partition it giving the OS 16GB, I can easily install Xubuntu Core in 10GB, so 16 will be more than enough. The internal HDD currently houses my Music, which is currently about 50GB, so I should have enough space for a few years to come.
2017-08-05, 00:13
Unfortunately the SSD was DOA. It was being sent by a guy I know in Sweden and I think either the Swedish postal service or the Royal Mail had been using it as football. Anyway I am now using a 2TB for my first Movies drive, another 1TB drive for a second movies drive and a 1TB for TV shows.
I was using ethernet over mains adaptors to network the house, but since I have upgraded to a Gigabit router I have now installed a Belkin 5 port Gigabit switch behind my TV which connects the server, my RPI2 and my retro games rig to the router and I am installing a Cisco Systems Catalyst 2960 8 port switch in the loft to feed into the RPI Model Bs I have in each bedroom. I will also put a Netgear N150 wireless access point in the loft to give better wifi coverage to the upper story of the house.
The Cisco switch also has a fibre channel port and I have scored a couple of fibre channel cards, so my plan is to use an old Acer Aspire X3200 as a proxy/OwnCloud server, once I get my head around fibre channel.
All of the above is all being done using kit that was heading for the skip just because it was old.
2017-09-16, 10:41
I finally said goodbye to my powerline adaptors today. They were becoming a pain. My neighbours have started using them and we share a common power supply. So my network traffic was bouncing off theirs. In the end I decided to go for flat cat 6 ethernet surface mounted along the skirting boards from my router upstairs to the Cisco Catalyst switch then out to each room. On the powerlines I was getting, on an RPI model B, 44 Mbps (tested with iperf) from the media server, if I was lucky. I now get 75 Mbps. I have just tested it with my desktop PC streaming a 1080p video and my RPI 2 also streaming a 1080p video and the RPI B in my bedroom was still getting 75 Mbps when tested with iperf.
2017-09-16, 22:24
Yep, nothing beats a real ethernet cable.
