This is an unofficial Deezer addon for Kodi. It works only for premium account and requires an account to access the service. It supports access to your playlists, albums, artists and tracks. It allows for browsing the chart and radio. Searching for tracks, albums and artists is also implemented. It plays the .mp3 tracks in 128kb resolution only as that's the max available bitrate for TV's from Deezer.
The api client is a work in progress and in the future I will implement adding/removing operations to manage the library, because so far only data retrieval is supported.
Version 0.1:
https://github.com/kubatek94/DeezerKodi/...deezer.zip
Source:
Big up to the author, kubatek94!
Just wanted to say thanks and good work. Installed version 0.0.2 and it works perfectly!
This is a great addon. I hope you add library operations soon. Thank you so much for your work.
Hello Friends
I work new whit kodi for my school now i wish that i can install deezer but its dont work can you please help me whit a little tutorial please?
Thanks a lot
(i work whit a raspberry pi 3)
Works just fine on Krypton with Windows. Thank you so much for this plugin. Hope you continue adding features to it.
Hey ray please help me how i can istall this addon? i dont understand which on file i must to be zip? every time in kodi its say structure errors
(2016-09-27, 16:54)Legotamil Wrote: [ -> ]Hey ray please help me how i can istall this addon? i dont understand which on file i must to be zip? every time in kodi its say structure errors
try with this zip. i'm on windows so I can't tell if it will be ok on rapsberry pi.
https://goo.gl/ucsdWo
Deezer plugin works great with OpenELEC 6.0.3 (Kodi v15). Had to remove xbmc.phyton requirement in addon.xml to be able to install it though.
Although, it seems like some songs or albums won't play (some albums are empty). Not sure if it's the API or the plugin that cause this problem, most stuff works though.
Think there's some problem with the plugin. When adding new playlists, or edit a playlist, with the normal app in the phone the changes doesn't appear in the plugin. It's like the stuff is being cached, and the cache doesn't get updated.
[EDIT] My bad, I forgot i had changed the password for my login
(2017-01-09, 16:17)zynex Wrote: [ -> ]Think there's some problem with the plugin. When adding new playlists, or edit a playlist, with the normal app in the phone the changes doesn't appear in the plugin. It's like the stuff is being cached, and the cache doesn't get updated.
No it is not a password issue, same as here, there is no refresh list.
It may be problematic in some modification of API.
I don't find that in the Kodi add-on repository (Music -> Addons -> More). Am I mistaken? Is there a chance to get into the repo?
Hello, the version 0,3 work in kodi 15 with a raspberry Pi. But It 'is possible to change the profil?
I have a account premium with 6 friends.
Thank
