Full Version: Kodi 16 RPi + Tvheadend 4.1 Synology
I have just installed the system in subject and all is perfect.
The only problem is that after some time of playing live tv (IPTV), the video and audio freeze.
This happens when watching live tv and also when recording.
I receive no errors. If recording, the recording finish with OK but alsways records only some minutes until the freeze.
If it freeze while watching with Kodi, it is ok to stop and then play again to get correct signal again or, in tvheadend configuration page, to cancel the Kodi subscription and the transmission suddenly continues again working good until next freeze.
I have been able to reproduce the error by activating a mux scan while playing live tv. It always freeze.
In tvheadend logs there is absolutely no errors....
Any help is appreciated.
Smile
Chris
Hi Chris,
I have the exact same issue when having tvheadend installed on a synology nas, after some time it freezes, all the time... quite ennoying !
Did you find any solution to your issue ?
Thanks a lot !
Cheers !
