2016-06-11, 00:56
Hi
I created this mod for aeon mq6 on jarvis
mq7 version http://forum.kodi.tv/showthread.php?tid=288301
Update 21/Aug/2016
-empty entries will no longer be shown (links updated)
Update 14/Jun/2016
-The rating images are now stored locally, so you need to download the files again also download flags file, extract it and put it inside your media folder
Update 13/Jun/2016 check new screenshots
-Now Logo, Banner, or Clearart shows instead of Movie title and TV Show title
-Added a top menu button [Dialogue Top Art] to switch between Logo, Banner, Clearart
-Zip files contains 3 files replace all 3 of them with your own inside 720p or 1080p folder
-Bugs fixed for 1080p in OSD View
Notes:-
-720p version is compatible with [ Skin MOD - Aeon MQ 6 - Moded version for I, J, K....] by Angelinas
-1080p version is compatible with [Aeon MQ 6 Spin-4.1 (24/04/16) ] by manfeed
-backup your data before applying this mod just to be safe
-this mod only available for movies
Featues
-Rottentommatos rating
-Metacritics rating
-IMDb rating
-Separator lines between ratings
-Animated clearart
-Animated Discart
-INFO Button in the menu bar to switch between rating info and basic info
the idea of putting the rating info in the middle is purely mine, other resources and info I have gathered around the forums.
enjoy
720p http://www.mediafire.com/download/16val4...w/720p.zip
1080p (Fixed bug) http://www.mediafire.com/download/ttbg71...pFIXED.zip
flags http://www.mediafire.com/download/3m6rbo.../flags.zip
Update 21/Aug/2016
Update 14/Jun/2016
Notes:-
Featues
-Metacritics rating
-IMDb rating
-Animated clearart
-Animated Discart
enjoy
