is it possible to play a video locally from the web interface?
I'm trying to play a video and trying to watch it from the web gui but it doesn't start.
thanks
well i think there are multiple possibilities.
with "web gui" do you mean chorus2? in chous2, as well in yarc, you can also download the items, depending on the browser, it also might stream it. important is, that the files have the right filetype (i made my dvd's to iso's and they don't work, but i also don't want to rip them all...).
i think there are also posibilities of airplay and upnp/dnla (<- don't know what this actually is). Also, the android app (one of them at least) has some streaming feature. but i have no idea about this stuff. but might be worth a closer look for you.
hope this is of any help for you.
yes I'm using chorus but I can play the video remotely from my pc and watch the movie in the TV but I can't play and watch the movie from my computer.
is it possible to watch the movie from the web gui are you sure?
yes i am sure, but i don't know what you try, have and expect. i was not inventing what i wrote above. so please give more context information.
do you use chorus, or chorus2?
are the settings set properly?
what fileformat do the media have?
are airplay or dnla(upnp) an option, did you read into it?
from "About" in the web interface I see:
Chorus 0.3.10
is it the first version?
I installed Chorus form the kodi web interface so I didn't see any other versions there.
I 've enabled upnp but not airplay.
the problem is that I can't watch or listen any format file in "local" but in XBMC mode instead work all of them fine.
well my chorus2 Version has the same number, so i suppose yes.
what formats do the files have?
did you try over download and stream in browser (with firefox and firefox mobile). btw. there seems to be a bug in this chorus version. it does not work, if it is not the default webinterface (
http://localhost:8088/addons/ does not work but
http://localhost:8088 would. localhost could also be an ip). this might also be the root of your problem in general.
Why not install kodi on the machine you want to watch on?
I need to watch a video via browser... is it possible with Kodi ? I dont' find any guide and any video about that.. it seems possible only theoretically
OK well this is a kodi forum, not an unnamed web browser forum.
I assume you have read the readme for chorus and chorus2. It clearly implies that the fault lies in browsers' inabilities to play many video codecs.
https://github.com/jez500/chorus2
Quote:Video streaming
Video streaming via HTML5 "sort of" works, it really depends on the codec used. An embedded VLC player is also available with better codec support. This looks like the best we can get until Kodi supports transcoding. Chrome users: Chrome has removed support for vlc/divx plugins so streaming a video requires a Chrome friendly codec.
You haven't explained why this desire is a "need" - perhaps if you do someone might know a usable alternative (other than the obvious, which I have already suggested)
