Is there any way to have the arrow keys, that skip forward and back with videos, do the same with live tv?
I keep hitting up arrow for a big skip and end up changing channels and losing the buffer.
Hi raptorjr,
I checked the link, but could not see anything for livetv.
I installed the keyboard editor, and it also has nothing for livetv. It does have pvr, but channel up/down are not set.
Can you provide further assistance?
Try something like:
<keymap>
<FullscreenLiveTV>
<remote>
<up>BigStepForward</up>
<down>BigStepBack</down>
</remote>
</FullscreenLiveTV>
</keymap>
Place that in a file in your userdata/keymaps/ directory.
Hi rpcameron,
I tried but it did not work.
I restarted kodi but up/down arrows still change channel.
It looked really promising
If Up/down is not set in the specified section then the Global section is used. Also you have to specify if you are using a remote or a keyboard.
The above example from rpcameron assumes a remote with mapped keys for up/down. Otherwise specify keyboard instead of remote, as described in the link I provided.
Thanks to you both.
Its working now.
I thought saying arrow keys, might be enough to indicate keyboard, will be more specific next time.
I figured the keyboard could be taken as a remote, so that part did not stand out.
