2016-07-18, 10:21
It's a very simple one, but thought some users might find it useful.
This is an export code to create a folder list for selected movies. The main purpose of this is to copy/move folders of selected movies to a different folder/drive. Many file managers offer "Load selection from a file (or clipboard)" feature. So you can export a list, select the folders using the command, and copy/move them.
You only need to create a new folder under "tmm\templates" with the following two text files to it.
list.jmte:
template.conf:
list.jmte:
${foreach movies movie}${movie.path}
${end}
template.conf:
name=Folder List
type=movie
list=list.jmte
extension=csv
description=Creates a folder list for selected movies
