Full Version: Error and crash when scraping
Hello,
First, excuse my bad english...
I use TMM for some time already, and I was quite satisfied.
But recently, I get an error when scraping.
Apparently this proviend of java, and I need your help to solve this problem if possible.
I would add that if I scrap directly since Kodi, information is found without any worry.
- In The log "Launcher", TMM is version 2.7.4 (first installation), as I am now in version 2.8.1.
Here is the error message obtained when scraping :
problem detected !
java.lang.NoClassDefFoundError: com/jakewharton/retrofit/Ok3Client
    at org.tinymediamanager.scraper.tmdb.TmdbMetadataProvider$1.newRestAdapterBuilder(TmdbMetadataProvider.java:79) ~[na:na]
    at com.uwetrottmann.tmdb.Tmdb.getRestAdapter(Tmdb.java:115) ~[na:na]
    at com.uwetrottmann.tmdb.Tmdb.findService(Tmdb.java:140) ~[na:na]
    at org.tinymediamanager.scraper.tmdb.TmdbMovieMetadataProvider.getTmdbIdFromImdbId(TmdbMovieMetadataProvider.java:362) ~[na:na]
    at org.tinymediamanager.scraper.tmdb.TmdbTrailerProvider.getTrailers(TmdbTrailerProvider.java:62) ~[na:na]
    at org.tinymediamanager.scraper.tmdb.TmdbMetadataProvider.getTrailers(TmdbMetadataProvider.java:174) ~[na:na]
    at org.tinymediamanager.ui.movies.MovieChooserModel$TrailerScrapeTask.run(MovieChooserModel.java:305) ~[tmm.jar:2.8.1]
    at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) ~[na:1.7.0_101]
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) ~[na:1.7.0_101]
    at java.lang.Thread.run(Thread.java:745) ~[na:1.7.0_101]
Here are the logs obtained :
launcher.log
2016/06/26 18:51:25:655 INFOS n.a: ------------------ VM Info ------------------
2016/06/26 18:51:25:657 INFOS n.a: -- OS Name: Linux
2016/06/26 18:51:25:657 INFOS n.a: -- OS Arch: amd64
2016/06/26 18:51:25:657 INFOS n.a: -- OS Vers: 3.13.0-88-generic
2016/06/26 18:51:25:657 INFOS n.a: -- Java Vers: 1.7.0_101
2016/06/26 18:51:25:658 INFOS n.a: -- Java Home: /usr/lib/jvm/java-7-openjdk-amd64/jre
2016/06/26 18:51:25:658 INFOS n.a: -- User Name: marc
2016/06/26 18:51:25:658 INFOS n.a: -- User Home: /home/marc
2016/06/26 18:51:25:658 INFOS n.a: -- Cur dir: /home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux
2016/06/26 18:51:25:658 INFOS n.a: ---------------------------------------------
2016/06/26 18:51:25:754 INFOS n.a: ---------------- Proxy Info -----------------
2016/06/26 18:51:25:755 INFOS n.a: -- Proxy Host: null
2016/06/26 18:51:25:755 INFOS n.a: -- Proxy Port: null
2016/06/26 18:51:25:755 INFOS n.a: ---------------------------------------------
2016/06/26 18:51:25:757 INFOS n.a: Skipping [quals=windows, osname=linux, osarch=amd64, key=resource, value=[windows] tinyMediaManager.new]
2016/06/26 18:51:25:758 INFOS n.a: Skipping [quals=windows, osname=linux, osarch=amd64, key=resource, value=[windows] tinyMediaManagerUpd.new]
2016/06/26 18:51:25:758 INFOS n.a: Skipping [quals=windows, osname=linux, osarch=amd64, key=resource, value=[windows] tinyMediaManagerCMD.new]
2016/06/26 18:51:25:758 INFOS n.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=resource, value=[mac os x] tinyMediaManagerOSX.sh]
2016/06/26 18:51:25:758 INFOS n.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=resource, value=[mac os x] JavaApplicationStub.new]
2016/06/26 18:51:25:758 INFOS n.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=resource, value=[mac os x] Info.plist]
2016/06/26 18:51:25:765 INFOS n.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=resource, value=[mac os x] native/mac/libmediainfo.dylib]
2016/06/26 18:51:25:766 INFOS n.a: Skipping [quals=windows-amd64, osname=linux, osarch=amd64, key=resource, value=[windows-amd64] native/windows-x64/MediaInfo.dll]
2016/06/26 18:51:25:767 INFOS n.a: Skipping [quals=windows-x64, osname=linux, osarch=amd64, key=resource, value=[windows-x64] native/windows-x64/MediaInfo.dll]
2016/06/26 18:51:25:769 INFOS n.a: Skipping [quals=windows-x86, osname=linux, osarch=amd64, key=resource, value=[windows-x86] native/windows-x86/MediaInfo.dll]
2016/06/26 18:51:25:769 INFOS n.a: Skipping [quals=windows-x86, osname=linux, osarch=amd64, key=resource, value=[windows-x86] native/windows-x86/mingwm10.dll]
2016/06/26 18:51:25:769 INFOS n.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=jvmarg, value=[mac os x] -Dapple.awt.graphics.UseQuartz=true]
2016/06/26 18:51:25:770 INFOS n.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=jvmarg, value=[mac os x] -Xdock:name=tinyMediaManager]
2016/06/26 18:51:25:770 INFOS n.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=jvmarg, value=[mac os x] -Dapple.eawt.quitStrategy=CLOSE_ALL_WINDOWS]
2016/06/26 18:51:25:773 INFOS n.a: Attempting to refetch 'digest.txt' from 'http://release.tinymediamanager.org/build/digest.txt'.
2016/06/26 18:51:26:974 INFOS n.a: remove verification files? true
2016/06/26 18:51:26:990 INFOS n.a: Able to lock for updates: true
2016/06/26 18:51:27:070 INFOS n.a: Verifying application: http://release.tinymediamanager.org/build/
2016/06/26 18:51:27:070 INFOS n.a: Version: -1
2016/06/26 18:51:27:070 INFOS n.a: Class: org.tinymediamanager.TinyMediaManager
2016/06/26 18:51:27:071 INFOS n.a: Dropping status 'm.validating'.
2016/06/26 18:51:27:105 INFOS n.a: Attempting to refetch 'digest.txt' from 'http://release.tinymediamanager.org/build/digest.txt'.
2016/06/26 18:51:27:248 INFOS n.a: No signers, not verifying file [path=digest.txt]
2016/06/26 18:51:29:582 INFOS n.a: Resources verified.
2016/06/26 18:51:29:584 INFOS n.a: Didn't find any custom environment variables, not setting any.
2016/06/26 18:51:29:584 INFOS n.a: Running /usr/lib/jvm/java-7-openjdk-amd64/jre/bin/java
  -classpath
  /home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./tmm.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/JTattoo.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/api-scraper.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/asm.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/betterbeansbinding-core.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/betterbeansbinding-el.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/betterbeansbinding-swingbinding.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/commons-codec.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/commons-io.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/commons-lang3.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/converter-gson.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/glazedlists_java15.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/gson.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/h2-mvstore.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/image-viewer.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/imgscalr-lib.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/jackson-annotations.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/jackson-core.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/jackson-databind.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/japura-gui.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/japura-util.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/jgoodies-common.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/jgoodies-forms.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/jmte.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/jna-platform.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/jna.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/joda-time.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/json.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/jsoup.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/jspf-core.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/jsr305.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/jtidy.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/logback-classic.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/logback-core.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/miglayout-core.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/miglayout-swing.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/okhttp-urlconnection.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/okhttp.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/okio.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/org.apache.oltu.oauth2.client.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/org.apache.oltu.oauth2.common.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/resources.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/retrofit.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/retrofit1-okhttp3-client.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/slf4j-api.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/trakt-java.jar:locale/*
  -Dcom.threerings.getdown=true
  -Xms64m
  -Xmx512m
  -Xss512k
  -Djava.net.preferIPv4Stack=true
  -Dfile.encoding=UTF-8
  -XX:CompileCommand=exclude,ca/odell/glazedlists/impl/filter/TextMatchers,matches
  -XX:CompileCommand=exclude,ca/odell/glazedlists/impl/filter/BoyerMooreCaseInsensitiveTextSearchStrategy,indexOf
  -Djna.nosys=true
tmm.log :
2016-07-18 13:03:35,916 DEBUG [main] org.tinymediamanager.core.Settings:242 - Loading settings from data
2016-07-18 13:03:36,817 INFO  [main] org.tinymediamanager.TinyMediaManager:149 - =====================================================
2016-07-18 13:03:36,817 INFO  [main] org.tinymediamanager.TinyMediaManager:150 - === tinyMediaManager (c) 2012-2016 Manuel Laggner ===
2016-07-18 13:03:36,817 INFO  [main] org.tinymediamanager.TinyMediaManager:151 - =====================================================
2016-07-18 13:03:36,873 INFO  [main] org.tinymediamanager.TinyMediaManager:152 - tmm.version      : 2.8.1
2016-07-18 13:03:36,873 INFO  [main] org.tinymediamanager.TinyMediaManager:158 - os.name          : Linux
2016-07-18 13:03:36,873 INFO  [main] org.tinymediamanager.TinyMediaManager:159 - os.version       : 3.13.0-92-generic
2016-07-18 13:03:36,873 INFO  [main] org.tinymediamanager.TinyMediaManager:160 - os.arch          : amd64
2016-07-18 13:03:36,949 INFO  [main] org.tinymediamanager.TinyMediaManager:162 - java.version     : 1.7.0_101
2016-07-18 13:03:36,950 INFO  [main] org.tinymediamanager.TinyMediaManager:522 - default encoding : UTF-8 | UTF8 | UTF-8
2016-07-18 13:03:36,951 INFO  [main] org.tinymediamanager.TinyMediaManager:522 - set encoding to  : UTF-8 | UTF8 | UTF-8
2016-07-18 13:03:36,951 INFO  [main] org.tinymediamanager.TinyMediaManager:187 - System language  : fr_FR
2016-07-18 13:03:36,951 INFO  [main] org.tinymediamanager.TinyMediaManager:188 - GUI language     : fr_FR
2016-07-18 13:03:37,016 INFO  [main] org.tinymediamanager.TinyMediaManager:189 - Scraper language : Française
2016-07-18 13:03:37,017 INFO  [main] org.tinymediamanager.TinyMediaManager:190 - TV Scraper lang  : Française
2016-07-18 13:03:37,898 INFO  [main] org.tinymediamanager.TinyMediaManager:238 - =====================================================
2016-07-18 13:03:37,967 DEBUG [main] org.tinymediamanager.TinyMediaManager:414 - Startup (0%) starting tinyMediaManager
2016-07-18 13:03:37,968 INFO  [main] org.tinymediamanager.TinyMediaManager:243 - starting tinyMediaManager
2016-07-18 13:03:37,976 DEBUG [main] org.tinymediamanager.TinyMediaManager:414 - Startup (20%) loading MediaInfo libs
2016-07-18 13:03:39,071 INFO  [main] o.t.thirdparty.MediaInfoUtils:74 - Using MediaInfoLib - v0.7.67
2016-07-18 13:03:39,073 DEBUG [main] org.tinymediamanager.TinyMediaManager:414 - Startup (30%) loading movie module
2016-07-18 13:03:45,042 INFO  [main] o.tinymediamanager.core.movie.MovieList:326 - found 2134 movies in database
2016-07-18 13:03:45,062 INFO  [main] o.tinymediamanager.core.movie.MovieList:346 - found 154 movieSets in database
2016-07-18 13:03:46,018 DEBUG [main] org.tinymediamanager.TinyMediaManager:414 - Startup (40%) loading TV show module
2016-07-18 13:03:46,589 INFO  [main] o.t.core.tvshow.TvShowList:266 - found 62 TV shows in database
2016-07-18 13:03:46,982 INFO  [main] o.t.core.tvshow.TvShowList:296 - found 1193 episodes in database
2016-07-18 13:03:47,021 DEBUG [main] org.tinymediamanager.TinyMediaManager:414 - Startup (50%) loading plugins
2016-07-18 13:03:47,090 DEBUG [main] o.t.scraper.util.PluginManager:61 - loading external plugins...
2016-07-18 13:03:47,328 WARN  [main] o.t.scraper.config.MediaProviderConfig:83 - Cannot load settings 'data/scraper_fanarttv.conf' - using defaults
2016-07-18 13:03:47,451 WARN  [main] o.t.scraper.config.MediaProviderConfig:83 - Cannot load settings 'data/scraper_opensubtitles.conf' - using defaults
2016-07-18 13:03:48,295 DEBUG [main] o.tinymediamanager.scraper.kodi.KodiUtil:284 - searching for Kodi commons
2016-07-18 13:03:48,300 DEBUG [main] o.tinymediamanager.scraper.kodi.KodiUtil:318 - Meh - could not find any common folders...
2016-07-18 13:03:48,300 DEBUG [main] o.tinymediamanager.scraper.kodi.KodiUtil:373 - Meh - could not find any common function...
2016-07-18 13:03:48,300 DEBUG [main] o.tinymediamanager.scraper.kodi.KodiUtil:214 - searching for Kodi scrapers
2016-07-18 13:03:48,304 DEBUG [main] o.tinymediamanager.scraper.kodi.KodiUtil:244 - Meh - could not find any scrapers...
2016-07-18 13:03:48,364 WARN  [main] o.t.scraper.config.MediaProviderConfig:83 - Cannot load settings 'data/scraper_imdb.conf' - using defaults
2016-07-18 13:03:48,398 DEBUG [main] o.t.scraper.util.PluginManager:72 - Done loading external plugins - took 00:00:01.304
2016-07-18 13:03:48,399 DEBUG [main] org.tinymediamanager.TinyMediaManager:414 - Startup (80%) loading ui
2016-07-18 13:03:49,160 DEBUG [main] o.tinymediamanager.ui.movies.MoviePanel:185 - loading MovieList
2016-07-18 13:03:51,951 DEBUG [SwingWorker-pool-4-thread-6] org.tinymediamanager.scraper.http.Url:232 - getting http://thetvdb.com/banners/actors/337053.jpg
2016-07-18 13:03:52,212 DEBUG [main] org.tinymediamanager.TinyMediaManager:414 - Startup (100%) finished starting :)
2016-07-18 13:03:52,279 DEBUG [trackEventThread] org.tinymediamanager.scraper.http.Url:232 - getting https://ssl.google-analytics.com/collect?v=1&tid=UA-35564534-5&cid=0ce5fad1-5c09-4977-844b-4791cb92d4b2&an=tinyMediaManager&av=2.8.1&t=event&ec=startup&ea=startup&aip=1&je=1&sc=start&ul=fr-FR&vp=1631x1026&cd1=Linux&cd2=amd64&cd3=1.7&cd4=2.8.1&cd5=0&z=1468839832273&sr=1680x1050
2016-07-18 13:03:57,212 INFO  [updateThread] org.tinymediamanager.core.UpdaterTask:67 - Checking for updates...
2016-07-18 13:03:57,230 DEBUG [updateThread] org.tinymediamanager.scraper.http.Url:232 - getting http://release.tinymediamanager.org/build/digest.txt?z=1468839837230
2016-07-18 13:03:58,236 INFO  [updateThread] org.tinymediamanager.core.UpdaterTask:150 - Already up2date :)
2016-07-18 13:03:58,270 DEBUG [main] org.tinymediamanager.ui.MainWindow:303 - update result was: false
2016-07-18 13:04:26,205 INFO  [SwingWorker-pool-4-thread-3] o.tinymediamanager.core.movie.MovieList:562 - =====================================================
2016-07-18 13:04:26,206 INFO  [SwingWorker-pool-4-thread-3] o.tinymediamanager.core.movie.MovieList:563 - Searching with scraper: tmdb, 1.3
2016-07-18 13:04:26,283 INFO  [SwingWorker-pool-4-thread-3] o.tinymediamanager.core.movie.MovieList:564 - MediaSearchOptions[type=MOVIE,query=Saint Amour,year=0,imdbId=,tmdbId=0,language=fr,country=France]
2016-07-18 13:04:26,283 INFO  [SwingWorker-pool-4-thread-3] o.tinymediamanager.core.movie.MovieList:565 - =====================================================
2016-07-18 13:04:30,509 INFO  [SwingWorker-pool-4-thread-5] o.tinymediamanager.core.movie.MovieList:562 - =====================================================
2016-07-18 13:04:30,509 INFO  [SwingWorker-pool-4-thread-5] o.tinymediamanager.core.movie.MovieList:563 - Searching with scraper: imdb, 1.4
2016-07-18 13:04:30,510 INFO  [SwingWorker-pool-4-thread-5] o.tinymediamanager.core.movie.MovieList:564 - MediaSearchOptions[type=MOVIE,query=Saint Amour,year=0,imdbId=,tmdbId=0,language=fr,country=France]
2016-07-18 13:04:30,510 INFO  [SwingWorker-pool-4-thread-5] o.tinymediamanager.core.movie.MovieList:565 - =====================================================
2016-07-18 13:04:30,511 DEBUG [SwingWorker-pool-4-thread-5] o.t.scraper.imdb.ImdbMetadataProvider:107 - search() MediaSearchOptions[type=MOVIE,query=Saint Amour,year=0,imdbId=,tmdbId=0,language=fr,country=France]
2016-07-18 13:04:30,518 DEBUG [SwingWorker-pool-4-thread-5] o.t.scraper.imdb.ImdbMovieParser:139 - ========= BEGIN IMDB Scraper Search for: http://www.imdb.com/find?q=Saint+Amour&s=tt
2016-07-18 13:04:30,521 DEBUG [SwingWorker-pool-4-thread-5] org.tinymediamanager.scraper.http.Url:232 - getting http://www.imdb.com/find?q=Saint+Amour&s=tt
2016-07-18 13:04:32,420 DEBUG [SwingWorker-pool-4-thread-5] o.t.scraper.util.MetadataUtil:53 - Similarity Score: [Saint Amour][Saint Amour]=[1.0]
2016-07-18 13:04:32,422 DEBUG [SwingWorker-pool-4-thread-5] o.t.scraper.util.MetadataUtil:53 - Similarity Score: [Saint Amour][Saint Amour]=[1.0]
2016-07-18 13:04:32,422 DEBUG [SwingWorker-pool-4-thread-5] o.t.scraper.imdb.ImdbMovieParser:317 - no poster - downgrading score by 0.01
2016-07-18 13:04:32,424 DEBUG [SwingWorker-pool-4-thread-5] o.t.scraper.util.MetadataUtil:53 - Similarity Score: [Saint Amour][Le curé de Saint-Amour]=[0.6956522]
2016-07-18 13:04:32,424 DEBUG [SwingWorker-pool-4-thread-5] o.t.scraper.imdb.ImdbMovieParser:317 - no poster - downgrading score by 0.01
2016-07-18 13:04:32,425 DEBUG [SwingWorker-pool-4-thread-5] o.t.scraper.util.MetadataUtil:53 - Similarity Score: [Saint Amour][Pour un amour lointain]=[0.6086956]
2016-07-18 13:04:32,426 DEBUG [SwingWorker-pool-4-thread-5] o.t.scraper.imdb.ImdbMovieParser:317 - no poster - downgrading score by 0.01
2016-07-18 13:04:32,427 DEBUG [SwingWorker-pool-4-thread-5] o.t.scraper.util.MetadataUtil:53 - Similarity Score: [Saint Amour][Saint-Tropez Blues]=[0.3478261]
2016-07-18 13:04:32,428 DEBUG [SwingWorker-pool-4-thread-5] o.t.scraper.imdb.ImdbMovieParser:317 - no poster - downgrading score by 0.01
2016-07-18 13:04:35,992 INFO  [SwingWorker-pool-4-thread-2] o.t.ui.movies.MovieChooserModel:172 - =====================================================
2016-07-18 13:04:35,992 INFO  [SwingWorker-pool-4-thread-2] o.t.ui.movies.MovieChooserModel:173 - Scraper metadata with scraper: imdb, 1.4
2016-07-18 13:04:35,994 INFO  [SwingWorker-pool-4-thread-2] o.t.ui.movies.MovieChooserModel:175 - MediaScrapeOptions[result=MediaSearchResult[providerId=imdb,url=<null>,title=Saint Amour,year=2016,originalTitle=<null>,id=<null>,score=1.0,imdbId=tt4589186,type=MOVIE,posterUrl=http://ia.media-imdb.com/images/M/MV5BYjEwYTFiNTktOTdjNy00NDE3LWEzODUtZDYzODA4YTFmYzIzXkEyXkFqcGdeQXVyNTYwMzk4MjM@._V1_UY200_AL_.jpg],ids={},type=MOVIE,artworkType=ALL,language=Française,country=France,fanartSize=Moyen: ~1280x720px,posterSize=Moyen: ~342x513px]
2016-07-18 13:04:35,996 INFO  [SwingWorker-pool-4-thread-2] o.t.ui.movies.MovieChooserModel:176 - =====================================================
2016-07-18 13:04:35,997 DEBUG [SwingWorker-pool-4-thread-2] o.t.scraper.imdb.ImdbMetadataProvider:88 - getMetadata() MediaScrapeOptions[result=MediaSearchResult[providerId=imdb,url=<null>,title=Saint Amour,year=2016,originalTitle=<null>,id=<null>,score=1.0,imdbId=tt4589186,type=MOVIE,posterUrl=http://ia.media-imdb.com/images/M/MV5BYjEwYTFiNTktOTdjNy00NDE3LWEzODUtZDYzODA4YTFmYzIzXkEyXkFqcGdeQXVyNTYwMzk4MjM@._V1_UY200_AL_.jpg],ids={},type=MOVIE,artworkType=ALL,language=Française,country=France,fanartSize=Moyen: ~1280x720px,posterSize=Moyen: ~342x513px]
2016-07-18 13:04:35,999 DEBUG [SwingWorker-pool-4-thread-2] o.t.scraper.imdb.ImdbMovieParser:109 - IMDB: getMetadata(imdbId): tt4589186
2016-07-18 13:04:36,003 DEBUG [pool-2-thread-1] org.tinymediamanager.scraper.http.Url:232 - getting http://www.imdb.com/title/tt4589186/combined
2016-07-18 13:04:36,007 DEBUG [SwingWorker-pool-4-thread-6] org.tinymediamanager.scraper.http.Url:232 - getting http://ia.media-imdb.com/images/M/MV5BYjEwYTFiNTktOTdjNy00NDE3LWEzODUtZDYzODA4YTFmYzIzXkEyXkFqcGdeQXVyNTYwMzk4MjM@._V1_UY200_AL_.jpg
2016-07-18 13:04:36,007 DEBUG [pool-2-thread-2] org.tinymediamanager.scraper.http.Url:232 - getting http://www.imdb.com/title/tt4589186/plotsummary
2016-07-18 13:04:46,231 ERROR [main] o.t.c.m.c.MovieToXbmcNfoConnector:492 - setData /run/user/1000/gvfs/smb-share:server=openelec,share=intenso/Films/Saint amour/Saint.Amour.2016.FRENCH.BDRip.x264-EXTREME.nfo
java.nio.file.NoSuchFileException: /run/user/1000/gvfs/smb-share:server=openelec,share=intenso/Films/Saint amour/Saint.Amour.2016.FRENCH.BDRip.x264-EXTREME.nfo
    at sun.nio.fs.UnixException.translateToIOException(UnixException.java:86) ~[na:1.7.0_101]
    at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:102) ~[na:1.7.0_101]
    at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:107) ~[na:1.7.0_101]
    at sun.nio.fs.UnixFileSystemProvider.newByteChannel(UnixFileSystemProvider.java:214) ~[na:1.7.0_101]
    at java.nio.file.spi.FileSystemProvider.newOutputStream(FileSystemProvider.java:430) ~[na:1.7.0_101]
    at java.nio.file.Files.newOutputStream(Files.java:172) ~[na:1.7.0_101]
    at java.nio.file.Files.write(Files.java:3092) ~[na:1.7.0_101]
    at org.tinymediamanager.core.Utils.writeStringToFile(Utils.java:1263) ~[tmm.jar:2.8.1]
    at org.tinymediamanager.core.movie.connector.MovieToXbmcNfoConnector.writeNfoFiles(MovieToXbmcNfoConnector.java:486) [tmm.jar:2.8.1]
    at org.tinymediamanager.core.movie.connector.MovieToXbmcNfoConnector.setData(MovieToXbmcNfoConnector.java:208) [tmm.jar:2.8.1]
    at org.tinymediamanager.core.movie.entities.Movie.writeNFO(Movie.java:1328) [tmm.jar:2.8.1]
    at org.tinymediamanager.core.movie.entities.Movie.setMetadata(Movie.java:942) [tmm.jar:2.8.1]
    at org.tinymediamanager.ui.movies.dialogs.MovieChooserDialog.actionPerformed(MovieChooserDialog.java:413) [tmm.jar:2.8.1]
    at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018) [na:1.7.0_101]
    at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341) [na:1.7.0_101]
    at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) [na:1.7.0_101]
    at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) [na:1.7.0_101]
    at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252) [na:1.7.0_101]
    at com.jtattoo.plaf.BaseButtonListener.mouseReleased(BaseButtonListener.java:60) [JTattoo.jar:1.6.12.1]
    at java.awt.Component.processMouseEvent(Component.java:6516) [na:1.7.0_101]
    at javax.swing.JComponent.processMouseEvent(JComponent.java:3312) [na:1.7.0_101]
    at java.awt.Component.processEvent(Component.java:6281) [na:1.7.0_101]
    at java.awt.Container.processEvent(Container.java:2229) [na:1.7.0_101]
    at java.awt.Component.dispatchEventImpl(Component.java:4872) [na:1.7.0_101]
    at java.awt.Container.dispatchEventImpl(Container.java:2287) [na:1.7.0_101]
    at java.awt.Component.dispatchEvent(Component.java:4698) [na:1.7.0_101]
    at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) [na:1.7.0_101]
    at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492) [na:1.7.0_101]
    at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) [na:1.7.0_101]
    at java.awt.Container.dispatchEventImpl(Container.java:2273) [na:1.7.0_101]
    at java.awt.Window.dispatchEventImpl(Window.java:2719) [na:1.7.0_101]
    at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) [na:1.7.0_101]
    at java.awt.EventQueue.access$300(EventQueue.java:103) [na:1.7.0_101]
    at java.awt.EventQueue$3.run(EventQueue.java:706) [na:1.7.0_101]
    at java.awt.EventQueue$3.run(EventQueue.java:704) [na:1.7.0_101]
    at java.security.AccessController.doPrivileged(Native Method) [na:1.7.0_101]
    at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:77) [na:1.7.0_101]
    at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:87) [na:1.7.0_101]
    at java.awt.EventQueue$4.run(EventQueue.java:720) [na:1.7.0_101]
    at java.awt.EventQueue$4.run(EventQueue.java:718) [na:1.7.0_101]
    at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) [na:1.7.0_101]
    at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) [na:1.7.0_101]
    at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) [na:1.7.0_101]
    at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:154) [na:1.7.0_101]
    at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:182) [na:1.7.0_101]
    at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:221) [na:1.7.0_101]
    at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:219) [na:1.7.0_101]
    at java.awt.Dialog.show(Dialog.java:1082) [na:1.7.0_101]
    at java.awt.Component.show(Component.java:1655) [na:1.7.0_101]
    at java.awt.Component.setVisible(Component.java:1607) [na:1.7.0_101]
    at java.awt.Window.setVisible(Window.java:1014) [na:1.7.0_101]
    at java.awt.Dialog.setVisible(Dialog.java:1005) [na:1.7.0_101]
    at org.tinymediamanager.ui.dialogs.TmmDialog.setVisible(TmmDialog.java:84) [tmm.jar:2.8.1]
    at org.tinymediamanager.ui.movies.dialogs.MovieChooserDialog.showDialog(MovieChooserDialog.java:614) [tmm.jar:2.8.1]
    at org.tinymediamanager.ui.movies.actions.MovieSingleScrapeAction.actionPerformed(MovieSingleScrapeAction.java:66) [tmm.jar:2.8.1]
    at javax.swing.AbstractButton.doClick(AbstractButton.java:376) [na:1.7.0_101]
    at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:833) [na:1.7.0_101]
    at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:877) [na:1.7.0_101]
    at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:289) [na:1.7.0_101]
    at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150) [na:1.7.0_101]
    at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146) [na:1.7.0_101]
    at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138) [na:1.7.0_101]
    at java.awt.EventDispatchThread.run(EventDispatchThread.java:91) [na:1.7.0_101]
2016-07-18 13:04:46,249 ERROR [main] o.t.c.m.c.MovieToXbmcNfoConnector:492 - setData /run/user/1000/gvfs/smb-share:server=openelec,share=intenso/Films/Saint amour/movie.nfo
java.nio.file.NoSuchFileException: /run/user/1000/gvfs/smb-share:server=openelec,share=intenso/Films/Saint amour/movie.nfo
2016-07-18 13:04:46,292 INFO  [main] o.t.core.movie.MovieRenamer:208 - Renaming movie: Saint Amour
2016-07-18 13:04:46,293 DEBUG [main] o.t.core.movie.MovieRenamer:209 - movie year: 2016
2016-07-18 13:04:46,293 DEBUG [main] o.t.core.movie.MovieRenamer:210 - movie path: /run/user/1000/gvfs/smb-share:server=openelec,share=intenso/Films/Saint amour
2016-07-18 13:04:46,293 DEBUG [main] o.t.core.movie.MovieRenamer:211 - movie isDisc?: false
2016-07-18 13:04:46,293 DEBUG [main] o.t.core.movie.MovieRenamer:212 - movie isMulti?: false
2016-07-18 13:04:46,294 DEBUG [main] o.t.core.movie.MovieRenamer:216 - path expression: $T ($Y)
2016-07-18 13:04:46,294 DEBUG [main] o.t.core.movie.MovieRenamer:217 - file expression: $T ($Y) $V $A
2016-07-18 13:04:46,295 DEBUG [main] o.t.core.movie.MovieRenamer:237 - movie willBeMulti?: false
2016-07-18 13:04:46,295 DEBUG [main] org.tinymediamanager.core.Utils:586 - try to move folder /run/user/1000/gvfs/smb-share:server=openelec,share=intenso/Films/Saint amour to /run/user/1000/gvfs/smb-share:server=openelec,share=intenso/Films/Saint Amour (2016)
2016-07-18 13:04:46,296 ERROR [main] o.t.core.movie.MovieRenamer:254 - error moving folder:
java.io.FileNotFoundException: Source '/run/user/1000/gvfs/smb-share:server=openelec,share=intenso/Films/Saint amour' does not exist, or is not a directory
    at org.tinymediamanager.core.Utils.moveDirectorySafe(Utils.java:588) ~[tmm.jar:2.8.1]
    at org.tinymediamanager.core.movie.MovieRenamer.renameMovie(MovieRenamer.java:245) ~[tmm.jar:2.8.1]
    at org.tinymediamanager.core.movie.entities.Movie.setMetadata(Movie.java:947) [tmm.jar:2.8.1]
2016-07-18 13:04:46,298 ERROR [main] o.t.core.movie.MovieRenamer:260 - Could not move to destination '/run/user/1000/gvfs/smb-share:server=openelec,share=intenso/Films/Saint Amour (2016)' - NOT renaming folder
2016-07-18 13:04:46,305 DEBUG [tmmpool-unnamed-task-thread-1] o.t.s.fanarttv.FanartTvMetadataProvider:89 - getArtwork() MediaScrapeOptions[result=<null>,ids={tmdb=0, imdb=tt4589186},type=MOVIE,artworkType=ALL,language=Française,country=France,fanartSize=Large: ~1920x1080px,posterSize=Grand: ~500x750px]
2016-07-18 13:04:46,309 DEBUG [tmmpool-unnamed-task-thread-2] o.t.scraper.ofdb.OfdbMetadataProvider:620 - getTrailers() MediaScrapeOptions[result=<null>,ids={tmdb=0, imdb=tt4589186},type=MOVIE,artworkType=ALL,language=Française,country=France,fanartSize=Moyen: ~1280x720px,posterSize=Moyen: ~342x513px]
2016-07-18 13:04:46,309 DEBUG [tmmpool-unnamed-task-thread-2] org.tinymediamanager.scraper.http.Url:232 - getting http://www.ofdb.de/view.php?page=suchergebnis&Kat=IMDb&SText=tt4589186
2016-07-18 13:04:46,322 DEBUG [tmmpool-unnamed-task-thread-1] o.t.s.fanarttv.FanartTvMetadataProvider:126 - getArtwork with IMDB id: tt4589186
2016-07-18 13:04:46,498 ERROR [tmmpool-unnamed-task-thread-1] org.tinymediamanager.Log4jBackstop:37 - Uncaught exception in thread: tmmpool-unnamed-task-thread-1
    at org.tinymediamanager.scraper.fanarttv.FanartTv.getRestAdapter(FanartTv.java:106) ~[na:na]
    at org.tinymediamanager.scraper.fanarttv.FanartTv.getMovieService(FanartTv.java:144) ~[na:na]
    at org.tinymediamanager.scraper.fanarttv.FanartTvMetadataProvider.getMovieArtwork(FanartTvMetadataProvider.java:127) ~[na:na]
    at org.tinymediamanager.scraper.fanarttv.FanartTvMetadataProvider.getArtwork(FanartTvMetadataProvider.java:95) ~[na:na]
    at org.tinymediamanager.ui.movies.MovieChooserModel$ArtworkScrapeTask.run(MovieChooserModel.java:256) ~[tmm.jar:2.8.1]
Caused by: java.lang.ClassNotFoundException: com.jakewharton.retrofit.Ok3Client
    at java.net.URLClassLoader$1.run(URLClassLoader.java:366) ~[na:1.7.0_101]
    at java.net.URLClassLoader$1.run(URLClassLoader.java:355) ~[na:1.7.0_101]
    at java.security.AccessController.doPrivileged(Native Method) ~[na:1.7.0_101]
    at java.net.URLClassLoader.findClass(URLClassLoader.java:354) ~[na:1.7.0_101]
    at java.lang.ClassLoader.loadClass(ClassLoader.java:425) ~[na:1.7.0_101]
    at org.codehaus.classworlds.RealmClassLoader.loadClassDirect(RealmClassLoader.java:128) ~[jspf-core.jar:na]
    at org.codehaus.classworlds.DefaultClassRealm.loadClassDirect(DefaultClassRealm.java:242) ~[jspf-core.jar:na]
    at org.codehaus.classworlds.DefaultClassRealm.loadClass(DefaultClassRealm.java:222) ~[jspf-core.jar:na]
    at org.codehaus.classworlds.RealmClassLoader.loadClass(RealmClassLoader.java:145) ~[jspf-core.jar:na]
    at java.lang.ClassLoader.loadClass(ClassLoader.java:358) ~[na:1.7.0_101]
    ... 8 common frames omitted
2016-07-18 13:04:48,177 DEBUG [tmmpool-unnamed-task-thread-2] o.t.scraper.ofdb.OfdbMetadataProvider:674 - found 1 search results
2016-07-18 13:04:48,177 DEBUG [tmmpool-unnamed-task-thread-2] o.t.scraper.ofdb.OfdbMetadataProvider:677 - get (trailer) details page
2016-07-18 13:04:48,179 DEBUG [tmmpool-unnamed-task-thread-2] org.tinymediamanager.scraper.http.Url:232 - getting http://www.ofdb.de/film/285203,Saint-Amour
2016-07-18 13:04:48,992 DEBUG [tmmpool-unnamed-task-thread-2] o.t.scraper.tmdb.TmdbTrailerProvider:54 - getTrailers() MediaScrapeOptions[result=<null>,ids={tmdb=0, imdb=tt4589186},type=MOVIE,artworkType=ALL,language=Française,country=France,fanartSize=Moyen: ~1280x720px,posterSize=Moyen: ~342x513px]
2016-07-18 13:04:49,009 ERROR [tmmpool-unnamed-task-thread-2] org.tinymediamanager.Log4jBackstop:37 - Uncaught exception in thread: tmmpool-unnamed-task-thread-2
Thank you in advance for your help and expert advice.
Thx, this has already been fixed in latest prerelease.
Release is already scheduled within the next 1-2 days)
Edit: or now :p
Good evening,
I updated to the 2.8.2 version, but still the same problem when scraping.
Here is the error resulting window :
java.lang.NoClassDefFoundError: retrofit2/Converter$Factory
    at org.tinymediamanager.scraper.tmdb.TmdbMetadataProvider.initAPI(TmdbMetadataProvider.java:78)
    at org.tinymediamanager.scraper.tmdb.TmdbMetadataProvider.getArtwork(TmdbMetadataProvider.java:168)
    at org.tinymediamanager.ui.movies.MovieChooserModel$ArtworkScrapeTask.run(MovieChooserModel.java:257)
Caused by: java.lang.ClassNotFoundException: retrofit2.Converter$Factory
    ... 6 common frames omitted
Just after, TMM crash, and I am forced to close and restart the application.
hmm.. artwork scraping works fine here with TMDB.
Could you please delete all /lib/retrofit* jars and start the updater again?
Maybe you could upload the whole logfile somewhere (and in this case the launcher.log could help here as well)
(the retrofit-2 jar seems to be missing in classpath somehow...)
As requested, I deleted all /lib/retrofit.jar, then retried an update, but without success.
Still the same error as above.
launcher.log :
2016/07/20 12:57:41:338 INFOS n.a: ------------------ VM Info ------------------
2016/07/20 12:57:41:340 INFOS n.a: -- OS Name: Linux
2016/07/20 12:57:41:340 INFOS n.a: -- OS Arch: amd64
2016/07/20 12:57:41:340 INFOS n.a: -- OS Vers: 3.13.0-92-generic
2016/07/20 12:57:41:341 INFOS n.a: -- Java Vers: 1.7.0_101
2016/07/20 12:57:41:341 INFOS n.a: -- Java Home: /usr/lib/jvm/java-7-openjdk-amd64/jre
2016/07/20 12:57:41:341 INFOS n.a: -- User Name: marc
2016/07/20 12:57:41:341 INFOS n.a: -- User Home: /home/marc
2016/07/20 12:57:41:341 INFOS n.a: -- Cur dir: /home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux
2016/07/20 12:57:41:341 INFOS n.a: ---------------------------------------------
2016/07/20 12:57:41:386 INFOS n.a: ---------------- Proxy Info -----------------
2016/07/20 12:57:41:386 INFOS n.a: -- Proxy Host: null
2016/07/20 12:57:41:386 INFOS n.a: -- Proxy Port: null
2016/07/20 12:57:41:387 INFOS n.a: ---------------------------------------------
2016/07/20 12:57:41:389 INFOS n.a: Skipping [quals=windows, osname=linux, osarch=amd64, key=resource, value=[windows] tinyMediaManager.new]
2016/07/20 12:57:41:389 INFOS n.a: Skipping [quals=windows, osname=linux, osarch=amd64, key=resource, value=[windows] tinyMediaManagerUpd.new]
2016/07/20 12:57:41:389 INFOS n.a: Skipping [quals=windows, osname=linux, osarch=amd64, key=resource, value=[windows] tinyMediaManagerCMD.new]
2016/07/20 12:57:41:390 INFOS n.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=resource, value=[mac os x] tinyMediaManagerOSX.sh]
2016/07/20 12:57:41:390 INFOS n.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=resource, value=[mac os x] JavaApplicationStub.new]
2016/07/20 12:57:41:390 INFOS n.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=resource, value=[mac os x] Info.plist]
2016/07/20 12:57:41:390 INFOS n.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=resource, value=[mac os x] native/mac/libmediainfo.dylib]
2016/07/20 12:57:41:391 INFOS n.a: Skipping [quals=windows-amd64, osname=linux, osarch=amd64, key=resource, value=[windows-amd64] native/windows-x64/MediaInfo.dll]
2016/07/20 12:57:41:391 INFOS n.a: Skipping [quals=windows-x64, osname=linux, osarch=amd64, key=resource, value=[windows-x64] native/windows-x64/MediaInfo.dll]
2016/07/20 12:57:41:392 INFOS n.a: Skipping [quals=windows-x86, osname=linux, osarch=amd64, key=resource, value=[windows-x86] native/windows-x86/MediaInfo.dll]
2016/07/20 12:57:41:392 INFOS n.a: Skipping [quals=windows-x86, osname=linux, osarch=amd64, key=resource, value=[windows-x86] native/windows-x86/mingwm10.dll]
2016/07/20 12:57:41:392 INFOS n.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=jvmarg, value=[mac os x] -Dapple.awt.graphics.UseQuartz=true]
2016/07/20 12:57:41:392 INFOS n.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=jvmarg, value=[mac os x] -Xdock:name=tinyMediaManager]
2016/07/20 12:57:41:393 INFOS n.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=jvmarg, value=[mac os x] -Dapple.eawt.quitStrategy=CLOSE_ALL_WINDOWS]
2016/07/20 12:57:41:396 INFOS n.a: Attempting to refetch 'digest.txt' from 'http://release.tinymediamanager.org/build/digest.txt'.
2016/07/20 12:57:41:628 INFOS n.a: remove verification files? true
2016/07/20 12:57:41:645 INFOS n.a: Able to lock for updates: true
2016/07/20 12:57:41:703 INFOS n.a: Verifying application: http://release.tinymediamanager.org/build/
2016/07/20 12:57:41:704 INFOS n.a: Version: -1
2016/07/20 12:57:41:704 INFOS n.a: Class: org.tinymediamanager.TinyMediaManager
2016/07/20 12:57:41:705 INFOS n.a: Dropping status 'm.validating'.
2016/07/20 12:57:41:731 INFOS n.a: Attempting to refetch 'digest.txt' from 'http://release.tinymediamanager.org/build/digest.txt'.
2016/07/20 12:57:41:870 INFOS n.a: No signers, not verifying file [path=digest.txt]
2016/07/20 12:57:41:883 INFOS n.a: Unversioned digest changed. Revalidating...
2016/07/20 12:57:41:936 INFOS n.a: file retrofit.jar seems not to be needed - deleting.
2016/07/20 12:57:41:962 INFOS n.a: Resource failed digest check [rsrc=getdown.txt, computed=69f5596e2defb616308a498cce03bdd1, expected=049a772691573476eb25bb687284c5f1]
2016/07/20 12:57:41:962 INFOS n.a: Attempting to refetch 'getdown.txt' from 'http://release.tinymediamanager.org/build/getdown.txt'.
2016/07/20 12:57:42:066 INFOS n.a: Attempting to refetch 'digest.txt' from 'http://release.tinymediamanager.org/build/digest.txt'.
2016/07/20 12:57:42:172 INFOS n.a: No signers, not verifying file [path=digest.txt]
2016/07/20 12:57:42:178 INFOS n.a: Skipping [quals=windows, osname=linux, osarch=amd64, key=resource, value=[windows] tinyMediaManager.new]
2016/07/20 12:57:42:179 INFOS n.a: Skipping [quals=windows, osname=linux, osarch=amd64, key=resource, value=[windows] tinyMediaManagerUpd.new]
2016/07/20 12:57:42:179 INFOS n.a: Skipping [quals=windows, osname=linux, osarch=amd64, key=resource, value=[windows] tinyMediaManagerCMD.new]
2016/07/20 12:57:42:179 INFOS n.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=resource, value=[mac os x] tinyMediaManagerOSX.sh]
2016/07/20 12:57:42:179 INFOS n.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=resource, value=[mac os x] JavaApplicationStub.new]
2016/07/20 12:57:42:182 INFOS n.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=resource, value=[mac os x] Info.plist]
2016/07/20 12:57:42:182 INFOS n.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=resource, value=[mac os x] native/mac/libmediainfo.dylib]
2016/07/20 12:57:42:182 INFOS n.a: Skipping [quals=windows-amd64, osname=linux, osarch=amd64, key=resource, value=[windows-amd64] native/windows-x64/MediaInfo.dll]
2016/07/20 12:57:42:182 INFOS n.a: Skipping [quals=windows-x64, osname=linux, osarch=amd64, key=resource, value=[windows-x64] native/windows-x64/MediaInfo.dll]
2016/07/20 12:57:42:182 INFOS n.a: Skipping [quals=windows-x86, osname=linux, osarch=amd64, key=resource, value=[windows-x86] native/windows-x86/MediaInfo.dll]
2016/07/20 12:57:42:183 INFOS n.a: Skipping [quals=windows-x86, osname=linux, osarch=amd64, key=resource, value=[windows-x86] native/windows-x86/mingwm10.dll]
2016/07/20 12:57:42:183 INFOS n.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=jvmarg, value=[mac os x] -Dapple.awt.graphics.UseQuartz=true]
2016/07/20 12:57:42:183 INFOS n.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=jvmarg, value=[mac os x] -Xdock:name=tinyMediaManager]
2016/07/20 12:57:42:183 INFOS n.a: Skipping [quals=mac os x, osname=linux, osarch=amd64, key=jvmarg, value=[mac os x] -Dapple.eawt.quitStrategy=CLOSE_ALL_WINDOWS]
2016/07/20 12:57:42:184 INFOS n.a: Attempting to refetch 'digest.txt' from 'http://release.tinymediamanager.org/build/digest.txt'.
2016/07/20 12:57:42:290 INFOS n.a: remove verification files? true
2016/07/20 12:57:42:601 INFOS n.a: Resource failed digest check [rsrc=tmm.jar, computed=6196186da9cbe463cec80d6a0241617e, expected=6d32cdec9c727cf81748b64a6e16ad8f]
2016/07/20 12:57:42:657 INFOS n.a: Resource failed digest check [rsrc=lib/api-scraper.jar, computed=2727ea70a3e6a57be2a77b84c40c34d8, expected=ed1f404320f3708edf16c858fc791e1f]
2016/07/20 12:57:42:782 INFOS n.a: Resource failed digest check [rsrc=lib/commons-io.jar, computed=94fc778439736ecd2f76346c6606b498, expected=c421c7e58a1f798cb8f8f2c5314cf713]
2016/07/20 12:57:42:861 INFOS n.a: Resource failed digest check [rsrc=lib/commons-logging.jar, error=java.io.FileNotFoundException: ./lib/commons-logging.jar (Aucun fichier ou dossier de ce type)]
2016/07/20 12:57:42:882 INFOS n.a: Resource failed digest check [rsrc=lib/converter-gson.jar, computed=5a850769fd6f8586c225b89b072f5553, expected=9ddd60ba07cbeed09de852f7ca7d2eff]
2016/07/20 12:57:43:039 INFOS n.a: Resource failed digest check [rsrc=lib/gson.jar, computed=df7373ca3083835a479724bf7ae29f92, expected=cf545f217cfd7d2a39ef45284d2e61d7]
2016/07/20 12:57:43:067 INFOS n.a: Resource failed digest check [rsrc=lib/jackson-annotations.jar, computed=ca355b1a9f94667a9adbbc9d78262941, expected=17c1a66b8f9b6fe119cf644370479053]
2016/07/20 12:57:43:082 INFOS n.a: Resource failed digest check [rsrc=lib/jackson-core.jar, computed=31b19d545d3194e6e286f5d18c588cfe, expected=f2591c74680d0743f929be4455ab6331]
2016/07/20 12:57:43:175 INFOS n.a: Resource failed digest check [rsrc=lib/jackson-databind.jar, computed=d708b55d4a7ac6d8f2a722131228a8f9, expected=78c23e0d368f3104b5ee96a15ffedb3e]
2016/07/20 12:57:43:696 INFOS n.a: Resource failed digest check [rsrc=lib/jsoup.jar, computed=0981a23bb0941e701f8041e5de6cd61a, expected=58a24028b60821b4a8034922e6056b56]
2016/07/20 12:57:43:788 INFOS n.a: Resource failed digest check [rsrc=lib/logback-classic.jar, computed=68256e4f25fa960bffe94988d28ad7e6, expected=523aa5a93eb36311394c24b808b69f77]
2016/07/20 12:57:43:826 INFOS n.a: Resource failed digest check [rsrc=lib/logback-core.jar, computed=92bac12388b70cce14111f2896dab16f, expected=66d950790e80fc414a415491ebbb50c6]
2016/07/20 12:57:43:826 INFOS n.a: Resource failed digest check [rsrc=lib/logging-interceptor.jar, error=java.io.FileNotFoundException: ./lib/logging-interceptor.jar (Aucun fichier ou dossier de ce type)]
2016/07/20 12:57:43:827 INFOS n.a: Resource failed digest check [rsrc=lib/loop-fs-api.jar, error=java.io.FileNotFoundException: ./lib/loop-fs-api.jar (Aucun fichier ou dossier de ce type)]
2016/07/20 12:57:43:827 INFOS n.a: Resource failed digest check [rsrc=lib/loop-fs-iso-impl.jar, error=java.io.FileNotFoundException: ./lib/loop-fs-iso-impl.jar (Aucun fichier ou dossier de ce type)]
2016/07/20 12:57:43:827 INFOS n.a: Resource failed digest check [rsrc=lib/loop-fs-spi.jar, error=java.io.FileNotFoundException: ./lib/loop-fs-spi.jar (Aucun fichier ou dossier de ce type)]
2016/07/20 12:57:43:834 INFOS n.a: Resource failed digest check [rsrc=lib/okhttp-urlconnection.jar, computed=1d55b7f5946c19bb344af18d09530964, expected=93c2ab10fedda1d0cced100aad33c8c2]
2016/07/20 12:57:43:990 INFOS n.a: Resource failed digest check [rsrc=lib/retrofit-1.9.0.jar, error=java.io.FileNotFoundException: ./lib/retrofit-1.9.0.jar (Aucun fichier ou dossier de ce type)]
2016/07/20 12:57:43:991 INFOS n.a: Resource failed digest check [rsrc=lib/retrofit-2.1.0.jar, error=java.io.FileNotFoundException: ./lib/retrofit-2.1.0.jar (Aucun fichier ou dossier de ce type)]
2016/07/20 12:57:44:009 INFOS n.a: Resource failed digest check [rsrc=lib/slf4j-api.jar, computed=17120a6e540c9542851a9bb9956d6277, expected=8b26153f6726944e667fbea08614ed25]
2016/07/20 12:57:44:018 INFOS n.a: Resource failed digest check [rsrc=plugins/scraper-anidb.jar, computed=a46a2ae5b5edd7c9c0c20d84162558d4, expected=cb3ad8a0896112600ad0224cc9b218db]
2016/07/20 12:57:44:020 INFOS n.a: Resource failed digest check [rsrc=plugins/scraper-fanarttv.jar, computed=2882fb394e8cfb7fd42528f6c2099008, expected=fede265944aea94412d59105c32972bb]
2016/07/20 12:57:44:023 INFOS n.a: Resource failed digest check [rsrc=plugins/scraper-imdb.jar, computed=08a8ce42e8c6ccdbbbccdaed7d0ba702, expected=b466095e3074a90ad39e2d3f734dd10f]
2016/07/20 12:57:44:027 INFOS n.a: Resource failed digest check [rsrc=plugins/scraper-moviemeter.jar, computed=8c47bfa566c9a810c0302de6258680b8, expected=b26ee14090002503f69d03e8b11cd7e7]
2016/07/20 12:57:44:045 INFOS n.a: Resource failed digest check [rsrc=plugins/scraper-tmdb.jar, computed=a2564a3bc3fa6b11b2365172c070d93e, expected=cac8fc9356591a810dc1642af9489c24]
2016/07/20 12:57:44:050 INFOS n.a: Resource failed digest check [rsrc=plugins/scraper-tvdb.jar, computed=c3c10ca1abf6c759e203287c2ce773ce, expected=93fa676a770c58cdaa458576aaaf08a1]
2016/07/20 12:57:44:051 INFOS n.a: Resource failed digest check [rsrc=plugins/scraper-zelluloid.jar, computed=195184f0d1343398e4fc8bbdeb46d2c2, expected=5327b99b88907939a06988469edb8ed9]
2016/07/20 12:57:44:171 INFOS n.a: Resource failed digest check [rsrc=version, computed=6e1aa5ff426e3b07e38923dfa3b51e63, expected=1a3ee4cefacf2d7c29374366e8e30d9b]
2016/07/20 12:57:44:179 INFOS n.a: Resource failed digest check [rsrc=changelog.txt, computed=f7f7695fb20e708fad9dd5c85c385b27, expected=e3698231dfd4486e727d86a8a25327c4]
2016/07/20 12:57:44:180 INFOS n.a: Resource failed digest check [rsrc=locale/messages_cs.properties, computed=76d6b233c0f75703fab5525ad8f9ba3d, expected=200a1f217dfa63629c7f26ba97d65581]
2016/07/20 12:57:44:180 INFOS n.a: Resource failed digest check [rsrc=locale/messages_da.properties, error=java.io.FileNotFoundException: ./locale/messages_da.properties (Aucun fichier ou dossier de ce type)]
2016/07/20 12:57:44:180 INFOS n.a: Resource failed digest check [rsrc=locale/messages_de.properties, computed=1614b001e92d404acfeca2c13e4a2ff1, expected=87a94df594d821e849cc974c4d32aa9e]
2016/07/20 12:57:44:181 INFOS n.a: Resource failed digest check [rsrc=locale/messages_el.properties, computed=fac575f2a41fcf1c174d0437730a8910, expected=4ff0ec423d9a5213d33033d2f993f2ed]
2016/07/20 12:57:44:182 INFOS n.a: Resource failed digest check [rsrc=locale/messages_es.properties, computed=9f27b46a0a2f68014ee2b1f2723287fe, expected=f500ea4ac04d7d5ecf26e9701066a39f]
2016/07/20 12:57:44:182 INFOS n.a: Resource failed digest check [rsrc=locale/messages_fr.properties, computed=e05b04bbd4d08171f044c413634f83b7, expected=a1e0334c82da929d2877149a82681a76]
2016/07/20 12:57:44:183 INFOS n.a: Resource failed digest check [rsrc=locale/messages_hu.properties, computed=0493dc0e9508cccb82df606ffc5ff801, expected=a85efaec14207d39f859ad848d224d83]
2016/07/20 12:57:44:183 INFOS n.a: Resource failed digest check [rsrc=locale/messages_it.properties, computed=2265136cfcc3daa2d9a5c09953dc4d35, expected=1f6701edef0babfd7c2024a90dc4ba7e]
2016/07/20 12:57:44:184 INFOS n.a: Resource failed digest check [rsrc=locale/messages_ko.properties, computed=721dd1a8c4ff5ac89f161714de0661da, expected=2c64cdb93662ce7fd5251430cbd13aa4]
2016/07/20 12:57:44:184 INFOS n.a: Resource failed digest check [rsrc=locale/messages_nl.properties, computed=06b40813cd645d094923ea2c8b3d3645, expected=18f181ed39faf7f0771aa22ae43dfaa6]
2016/07/20 12:57:44:185 INFOS n.a: Resource failed digest check [rsrc=locale/messages_no.properties, computed=0a57aa7fd05379279f24f32937fcb966, expected=0d138a957fe071ffe64dffc348bbead1]
2016/07/20 12:57:44:185 INFOS n.a: Resource failed digest check [rsrc=locale/messages_pl.properties, computed=2e99a24f805ed142445faf919ec6f0ec, expected=f507e86531742545c2d537e8db8db2a5]
2016/07/20 12:57:44:186 INFOS n.a: Resource failed digest check [rsrc=locale/messages_pt.properties, computed=2b6fc7c91ab308f0bed8659e940a88dd, expected=b5a968b1c55ddac17924785584d9358f]
2016/07/20 12:57:44:186 INFOS n.a: Resource failed digest check [rsrc=locale/messages_pt_BR.properties, error=java.io.FileNotFoundException: ./locale/messages_pt_BR.properties (Aucun fichier ou dossier de ce type)]
2016/07/20 12:57:44:187 INFOS n.a: Resource failed digest check [rsrc=locale/messages_ru.properties, computed=1a67fdd2e21d337fdd9b24f8f9cc89d4, expected=07dd93b1d82712e3202bd442b017b3be]
2016/07/20 12:57:44:188 INFOS n.a: Resource failed digest check [rsrc=locale/messages_sk.properties, computed=400ef09019534ac893959cd7ac3ee5e2, expected=ad670220c13f64fcdccf9b74b1f08107]
2016/07/20 12:57:44:189 INFOS n.a: Resource failed digest check [rsrc=locale/messages_sv.properties, computed=a22ecd4f26e5095fc040bdcfdc7b8d04, expected=4126eb0091ea9dcf5f01565dd7ee4d6f]
2016/07/20 12:57:44:189 INFOS n.a: Resource failed digest check [rsrc=locale/messages_tr.properties, computed=6e2ca8546cc296454286759d990970d0, expected=3064d751ec01a4d81a6eb3fa6a37b15e]
2016/07/20 12:57:44:189 INFOS n.a: Resource failed digest check [rsrc=locale/messages_vi.properties, error=java.io.FileNotFoundException: ./locale/messages_vi.properties (Aucun fichier ou dossier de ce type)]
2016/07/20 12:57:44:190 INFOS n.a: Resource failed digest check [rsrc=locale/messages_zh.properties, computed=951b46ddb4aa0562f040652707ea6dcc, expected=22d96a39d9e76b1197d90f5b86d88ed9]
2016/07/20 12:57:44:197 INFOS n.a: Resource failed digest check [rsrc=templates/DetailExampleHtml.jar, computed=8b15a4cfb26ab7934013760ac61dc86b, expected=30dec9d914ade8c921e05635c25b03f9]
2016/07/20 12:57:44:418 INFOS n.a: 50 of 102 rsrcs require update (0 assumed valid).
2016/07/20 12:57:48:095 INFOS n.a: Downloading 6741017 bytes...
2016/07/20 12:57:48:173 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/tmm.jar, size=1984400]
2016/07/20 12:57:57:966 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/lib/api-scraper.jar, size=125157]
2016/07/20 12:57:58:647 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/lib/commons-io.jar, size=208700]
2016/07/20 12:57:59:699 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/lib/commons-logging.jar, size=38015]
2016/07/20 12:57:59:945 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/lib/converter-gson.jar, size=5494]
2016/07/20 12:58:00:073 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/lib/gson.jar, size=231952]
2016/07/20 12:58:01:213 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/lib/jackson-annotations.jar, size=55784]
2016/07/20 12:58:01:537 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/lib/jackson-core.jar, size=280015]
2016/07/20 12:58:02:893 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/lib/jackson-databind.jar, size=1228993]
2016/07/20 12:58:08:423 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/lib/jsoup.jar, size=319052]
2016/07/20 12:58:09:909 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/lib/logback-classic.jar, size=304075]
2016/07/20 12:58:11:416 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/lib/logback-core.jar, size=470782]
2016/07/20 12:58:13:652 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/lib/logging-interceptor.jar, size=8043]
2016/07/20 12:58:13:761 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/lib/loop-fs-api.jar, size=4560]
2016/07/20 12:58:13:878 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/lib/loop-fs-iso-impl.jar, size=15219]
2016/07/20 12:58:14:020 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/lib/loop-fs-spi.jar, size=8121]
2016/07/20 12:58:14:131 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/lib/okhttp-urlconnection.jar, size=26874]
2016/07/20 12:58:14:323 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/lib/retrofit-1.9.0.jar, size=121559]
2016/07/20 12:58:14:937 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/lib/retrofit-2.1.0.jar, size=88343]
2016/07/20 12:58:15:400 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/lib/slf4j-api.jar, size=41071]
2016/07/20 12:58:15:660 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/plugins/scraper-anidb.jar, size=30120]
2016/07/20 12:58:15:869 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/plugins/scraper-fanarttv.jar, size=30182]
2016/07/20 12:58:16:079 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/plugins/scraper-imdb.jar, size=39700]
2016/07/20 12:58:16:329 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/plugins/scraper-moviemeter.jar, size=27064]
2016/07/20 12:58:16:521 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/plugins/scraper-tmdb.jar, size=103722]
2016/07/20 12:58:17:063 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/plugins/scraper-tvdb.jar, size=62735]
2016/07/20 12:58:17:422 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/plugins/scraper-zelluloid.jar, size=15965]
2016/07/20 12:58:17:562 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/version, size=137]
2016/07/20 12:58:17:637 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/changelog.txt, size=3696]
2016/07/20 12:58:17:726 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/locale/messages_cs.properties, size=40953]
2016/07/20 12:58:17:982 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/locale/messages_da.properties, size=38526]
2016/07/20 12:58:18:225 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/locale/messages_de.properties, size=41795]
2016/07/20 12:58:18:481 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/locale/messages_el.properties, size=60645]
2016/07/20 12:58:18:821 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/locale/messages_es.properties, size=44098]
2016/07/20 12:58:19:136 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/locale/messages_fr.properties, size=45558]
2016/07/20 12:58:19:409 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/locale/messages_hu.properties, size=41292]
2016/07/20 12:58:19:705 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/locale/messages_it.properties, size=41119]
2016/07/20 12:58:19:961 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/locale/messages_ko.properties, size=40078]
2016/07/20 12:58:20:213 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/locale/messages_nl.properties, size=40283]
2016/07/20 12:58:20:462 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/locale/messages_no.properties, size=39337]
2016/07/20 12:58:20:711 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/locale/messages_pl.properties, size=41561]
2016/07/20 12:58:20:968 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/locale/messages_pt.properties, size=42034]
2016/07/20 12:58:21:230 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/locale/messages_pt_BR.properties, size=39035]
2016/07/20 12:58:21:476 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/locale/messages_ru.properties, size=60626]
2016/07/20 12:58:21:823 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/locale/messages_sk.properties, size=41795]
2016/07/20 12:58:22:209 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/locale/messages_sv.properties, size=40811]
2016/07/20 12:58:22:482 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/locale/messages_tr.properties, size=41519]
2016/07/20 12:58:22:739 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/locale/messages_vi.properties, size=38793]
2016/07/20 12:58:22:989 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/locale/messages_zh.properties, size=37188]
2016/07/20 12:58:23:232 INFOS n.a: Downloading resource [url=http://release.tinymediamanager.org/build/templates/DetailExampleHtml.jar, size=4441]
2016/07/20 12:58:23:243 INFOS n.a: Verifying application: http://release.tinymediamanager.org/build/
2016/07/20 12:58:23:243 INFOS n.a: Version: -1
2016/07/20 12:58:23:243 INFOS n.a: Class: org.tinymediamanager.TinyMediaManager
2016/07/20 12:58:23:244 INFOS n.a: Attempting to refetch 'digest.txt' from 'http://release.tinymediamanager.org/build/digest.txt'.
2016/07/20 12:58:23:348 INFOS n.a: No signers, not verifying file [path=digest.txt]
2016/07/20 12:58:24:275 INFOS n.a: Resources verified.
2016/07/20 12:58:24:277 INFOS n.a: Didn't find any custom environment variables, not setting any.
2016/07/20 12:58:24:277 INFOS n.a: Running /usr/lib/jvm/java-7-openjdk-amd64/jre/bin/java
  -classpath
  /home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./tmm.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/JTattoo.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/api-scraper.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/asm.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/betterbeansbinding-core.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/betterbeansbinding-el.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/betterbeansbinding-swingbinding.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/commons-codec.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/commons-io.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/commons-lang3.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/commons-logging.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/converter-gson.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/glazedlists_java15.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/gson.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/h2-mvstore.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/image-viewer.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/imgscalr-lib.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/jackson-annotations.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/jackson-core.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/jackson-databind.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/japura-gui.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/japura-util.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/jgoodies-common.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/jgoodies-forms.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/jmte.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/jna-platform.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/jna.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/joda-time.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/json.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/jsoup.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/jspf-core.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/jsr305.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/jtidy.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/logback-classic.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/logback-core.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/logging-interceptor.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/loop-fs-api.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/loop-fs-iso-impl.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/loop-fs-spi.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/miglayout-core.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/miglayout-swing.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/okhttp-urlconnection.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/okhttp.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/okio.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/org.apache.oltu.oauth2.client.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/org.apache.oltu.oauth2.common.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/resources.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/retrofit-1.9.0.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/retrofit-2.1.0.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/retrofit1-okhttp3-client.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/slf4j-api.jar:/home/marc/TinyMediaManager/tmm_2.7.4_fceff9c_linux/./lib/trakt-java.jar:locale/*:locale/*
  -Xms64m
  -Xmx512m
  -Xss512k
  -Djna.nosys=true
tmm.log :
2016-07-21 12:04:06,368 DEBUG [main] org.tinymediamanager.core.Settings:242 - Loading settings from data
2016-07-21 12:04:06,601 INFO  [main] org.tinymediamanager.TinyMediaManager:149 - =====================================================
2016-07-21 12:04:06,602 INFO  [main] org.tinymediamanager.TinyMediaManager:150 - === tinyMediaManager (c) 2012-2016 Manuel Laggner ===
2016-07-21 12:04:06,602 INFO  [main] org.tinymediamanager.TinyMediaManager:151 - =====================================================
2016-07-21 12:04:06,605 INFO  [main] org.tinymediamanager.TinyMediaManager:152 - tmm.version      : 2.8.2
2016-07-21 12:04:06,605 INFO  [main] org.tinymediamanager.TinyMediaManager:158 - os.name          : Linux
2016-07-21 12:04:06,606 INFO  [main] org.tinymediamanager.TinyMediaManager:159 - os.version       : 3.13.0-92-generic
2016-07-21 12:04:06,606 INFO  [main] org.tinymediamanager.TinyMediaManager:160 - os.arch          : amd64
2016-07-21 12:04:06,611 INFO  [main] org.tinymediamanager.TinyMediaManager:162 - java.version     : 1.7.0_101
2016-07-21 12:04:06,611 INFO  [main] org.tinymediamanager.TinyMediaManager:522 - default encoding : UTF-8 | UTF8 | UTF-8
2016-07-21 12:04:06,612 INFO  [main] org.tinymediamanager.TinyMediaManager:522 - set encoding to  : UTF-8 | UTF8 | UTF-8
2016-07-21 12:04:06,612 INFO  [main] org.tinymediamanager.TinyMediaManager:187 - System language  : fr_FR
2016-07-21 12:04:06,613 INFO  [main] org.tinymediamanager.TinyMediaManager:188 - GUI language     : fr_FR
2016-07-21 12:04:06,616 INFO  [main] org.tinymediamanager.TinyMediaManager:189 - Scraper language : Française
2016-07-21 12:04:06,616 INFO  [main] org.tinymediamanager.TinyMediaManager:190 - TV Scraper lang  : Française
2016-07-21 12:04:06,858 INFO  [main] org.tinymediamanager.TinyMediaManager:238 - =====================================================
2016-07-21 12:04:06,875 DEBUG [main] org.tinymediamanager.TinyMediaManager:414 - Startup (0%) starting tinyMediaManager
2016-07-21 12:04:06,877 INFO  [main] org.tinymediamanager.TinyMediaManager:243 - starting tinyMediaManager
2016-07-21 12:04:06,886 DEBUG [main] org.tinymediamanager.TinyMediaManager:414 - Startup (20%) loading MediaInfo libs
2016-07-21 12:04:07,074 INFO  [main] o.t.thirdparty.MediaInfoUtils:74 - Using MediaInfoLib - v0.7.67
2016-07-21 12:04:07,076 DEBUG [main] org.tinymediamanager.TinyMediaManager:414 - Startup (30%) loading movie module
2016-07-21 12:04:09,757 INFO  [main] o.tinymediamanager.core.movie.MovieList:326 - found 2134 movies in database
2016-07-21 12:04:09,776 INFO  [main] o.tinymediamanager.core.movie.MovieList:346 - found 154 movieSets in database
2016-07-21 12:04:14,181 DEBUG [main] org.tinymediamanager.TinyMediaManager:414 - Startup (40%) loading TV show module
2016-07-21 12:04:14,405 INFO  [main] o.t.core.tvshow.TvShowList:281 - found 62 TV shows in database
2016-07-21 12:04:14,745 INFO  [main] o.t.core.tvshow.TvShowList:311 - found 1193 episodes in database
2016-07-21 12:04:14,816 DEBUG [main] org.tinymediamanager.TinyMediaManager:414 - Startup (50%) loading plugins
2016-07-21 12:04:14,891 DEBUG [main] o.t.scraper.util.PluginManager:61 - loading external plugins...
2016-07-21 12:04:15,000 WARN  [main] o.t.scraper.config.MediaProviderConfig:83 - Cannot load settings 'data/scraper_tmdb.conf' - using defaults
2016-07-21 12:04:15,009 WARN  [main] o.t.scraper.config.MediaProviderConfig:83 - Cannot load settings 'data/scraper_opensubtitles.conf' - using defaults
2016-07-21 12:04:15,369 DEBUG [main] o.tinymediamanager.scraper.kodi.KodiUtil:284 - searching for Kodi commons
2016-07-21 12:04:15,371 DEBUG [main] o.tinymediamanager.scraper.kodi.KodiUtil:318 - Meh - could not find any common folders...
2016-07-21 12:04:15,371 DEBUG [main] o.tinymediamanager.scraper.kodi.KodiUtil:373 - Meh - could not find any common function...
2016-07-21 12:04:15,371 DEBUG [main] o.tinymediamanager.scraper.kodi.KodiUtil:214 - searching for Kodi scrapers
2016-07-21 12:04:15,373 DEBUG [main] o.tinymediamanager.scraper.kodi.KodiUtil:244 - Meh - could not find any scrapers...
2016-07-21 12:04:15,419 WARN  [main] o.t.scraper.config.MediaProviderConfig:83 - Cannot load settings 'data/scraper_imdb.conf' - using defaults
2016-07-21 12:04:15,459 DEBUG [main] o.t.scraper.util.PluginManager:72 - Done loading external plugins - took 00:00:00.557
2016-07-21 12:04:15,466 DEBUG [main] org.tinymediamanager.TinyMediaManager:414 - Startup (80%) loading ui
2016-07-21 12:04:16,024 DEBUG [main] o.tinymediamanager.ui.movies.MoviePanel:185 - loading MovieList
2016-07-21 12:04:18,020 DEBUG [SwingWorker-pool-4-thread-6] org.tinymediamanager.scraper.http.Url:232 - getting http://thetvdb.com/banners/actors/337053.jpg
2016-07-21 12:04:18,204 DEBUG [main] org.tinymediamanager.TinyMediaManager:414 - Startup (100%) finished starting :)
2016-07-21 12:04:18,216 DEBUG [trackEventThread] org.tinymediamanager.scraper.http.Url:232 - getting https://ssl.google-analytics.com/collect?v=1&tid=UA-35564534-5&cid=0ce5fad1-5c09-4977-844b-4791cb92d4b2&an=tinyMediaManager&av=2.8.2&t=event&ec=startup&ea=startup&aip=1&je=1&sc=start&ul=fr-FR&vp=1631x1026&cd1=Linux&cd2=amd64&cd3=1.7&cd4=2.8.2&cd5=0&z=1469095458215&sr=1680x1050
2016-07-21 12:04:23,204 INFO  [updateThread] org.tinymediamanager.core.UpdaterTask:67 - Checking for updates...
2016-07-21 12:04:23,207 DEBUG [updateThread] org.tinymediamanager.scraper.http.Url:232 - getting http://release.tinymediamanager.org/build/digest.txt?z=1469095463206
2016-07-21 12:04:23,491 INFO  [updateThread] org.tinymediamanager.core.UpdaterTask:150 - Already up2date :)
2016-07-21 12:04:23,525 DEBUG [main] org.tinymediamanager.ui.MainWindow:303 - update result was: false
in your log there is nothing that indicates a crash?
Hello,
I just try again, always the same concern when scraping.
For example, with the movie Saint Amour (2016), research with TMDB find nothing (directly in Kodi it works).
Then attempt to IMDB, the title is found in English, but when I click on approval to import the data, the following error message:
Some unexpected thing happened.
Restart TMM please again.
If it happens again, please submit a bug report
(see post # 3).
Finally, at the bottom right of TMM "execute helper in the background" scans indefinitely.
Here is the latest log tmm I just made:
2016-07-24 08:30:26,348 DEBUG [main] org.tinymediamanager.core.Settings:242 - Loading settings from data
2016-07-24 08:30:27,381 INFO  [main] org.tinymediamanager.TinyMediaManager:149 - =====================================================
2016-07-24 08:30:27,382 INFO  [main] org.tinymediamanager.TinyMediaManager:150 - === tinyMediaManager (c) 2012-2016 Manuel Laggner ===
2016-07-24 08:30:27,383 INFO  [main] org.tinymediamanager.TinyMediaManager:151 - =====================================================
2016-07-24 08:30:27,398 INFO  [main] org.tinymediamanager.TinyMediaManager:152 - tmm.version      : 2.8.2
2016-07-24 08:30:27,399 INFO  [main] org.tinymediamanager.TinyMediaManager:158 - os.name          : Linux
2016-07-24 08:30:27,399 INFO  [main] org.tinymediamanager.TinyMediaManager:159 - os.version       : 3.13.0-92-generic
2016-07-24 08:30:27,399 INFO  [main] org.tinymediamanager.TinyMediaManager:160 - os.arch          : amd64
2016-07-24 08:30:27,418 INFO  [main] org.tinymediamanager.TinyMediaManager:162 - java.version     : 1.7.0_101
2016-07-24 08:30:27,419 INFO  [main] org.tinymediamanager.TinyMediaManager:522 - default encoding : UTF-8 | UTF8 | UTF-8
2016-07-24 08:30:27,419 INFO  [main] org.tinymediamanager.TinyMediaManager:522 - set encoding to  : UTF-8 | UTF8 | UTF-8
2016-07-24 08:30:27,419 INFO  [main] org.tinymediamanager.TinyMediaManager:187 - System language  : fr_FR
2016-07-24 08:30:27,420 INFO  [main] org.tinymediamanager.TinyMediaManager:188 - GUI language     : fr_FR
2016-07-24 08:30:27,452 INFO  [main] org.tinymediamanager.TinyMediaManager:189 - Scraper language : Française
2016-07-24 08:30:27,452 INFO  [main] org.tinymediamanager.TinyMediaManager:190 - TV Scraper lang  : Française
2016-07-24 08:30:28,234 INFO  [main] org.tinymediamanager.TinyMediaManager:238 - =====================================================
2016-07-24 08:30:28,286 DEBUG [main] org.tinymediamanager.TinyMediaManager:414 - Startup (0%) starting tinyMediaManager
2016-07-24 08:30:28,287 INFO  [main] org.tinymediamanager.TinyMediaManager:243 - starting tinyMediaManager
2016-07-24 08:30:28,288 DEBUG [main] org.tinymediamanager.TinyMediaManager:414 - Startup (20%) loading MediaInfo libs
2016-07-24 08:30:29,002 INFO  [main] o.t.thirdparty.MediaInfoUtils:74 - Using MediaInfoLib - v0.7.67
2016-07-24 08:30:29,003 DEBUG [main] org.tinymediamanager.TinyMediaManager:414 - Startup (30%) loading movie module
2016-07-24 08:30:32,526 INFO  [main] o.tinymediamanager.core.movie.MovieList:326 - found 2134 movies in database
2016-07-24 08:30:32,544 INFO  [main] o.tinymediamanager.core.movie.MovieList:346 - found 154 movieSets in database
2016-07-24 08:30:36,904 DEBUG [main] org.tinymediamanager.TinyMediaManager:414 - Startup (40%) loading TV show module
2016-07-24 08:30:37,464 INFO  [main] o.t.core.tvshow.TvShowList:281 - found 62 TV shows in database
2016-07-24 08:30:37,811 INFO  [main] o.t.core.tvshow.TvShowList:311 - found 1193 episodes in database
2016-07-24 08:30:37,882 DEBUG [main] org.tinymediamanager.TinyMediaManager:414 - Startup (50%) loading plugins
2016-07-24 08:30:37,979 DEBUG [main] o.t.scraper.util.PluginManager:61 - loading external plugins...
2016-07-24 08:30:38,227 WARN  [main] o.t.scraper.config.MediaProviderConfig:83 - Cannot load settings 'data/scraper_tmdb.conf' - using defaults
2016-07-24 08:30:38,298 WARN  [main] o.t.scraper.config.MediaProviderConfig:83 - Cannot load settings 'data/scraper_opensubtitles.conf' - using defaults
2016-07-24 08:30:39,123 DEBUG [main] o.tinymediamanager.scraper.kodi.KodiUtil:284 - searching for Kodi commons
2016-07-24 08:30:39,130 DEBUG [main] o.tinymediamanager.scraper.kodi.KodiUtil:318 - Meh - could not find any common folders...
2016-07-24 08:30:39,131 DEBUG [main] o.tinymediamanager.scraper.kodi.KodiUtil:373 - Meh - could not find any common function...
2016-07-24 08:30:39,131 DEBUG [main] o.tinymediamanager.scraper.kodi.KodiUtil:214 - searching for Kodi scrapers
2016-07-24 08:30:39,133 DEBUG [main] o.tinymediamanager.scraper.kodi.KodiUtil:244 - Meh - could not find any scrapers...
2016-07-24 08:30:39,202 WARN  [main] o.t.scraper.config.MediaProviderConfig:83 - Cannot load settings 'data/scraper_imdb.conf' - using defaults
2016-07-24 08:30:39,258 DEBUG [main] o.t.scraper.util.PluginManager:72 - Done loading external plugins - took 00:00:01.276
2016-07-24 08:30:39,259 DEBUG [main] org.tinymediamanager.TinyMediaManager:414 - Startup (80%) loading ui
2016-07-24 08:30:39,954 DEBUG [main] o.tinymediamanager.ui.movies.MoviePanel:185 - loading MovieList
2016-07-24 08:30:42,628 DEBUG [SwingWorker-pool-4-thread-6] org.tinymediamanager.scraper.http.Url:232 - getting http://thetvdb.com/banners/actors/337053.jpg
2016-07-24 08:30:42,775 DEBUG [main] org.tinymediamanager.TinyMediaManager:414 - Startup (100%) finished starting :)
2016-07-24 08:30:42,892 DEBUG [trackEventThread] org.tinymediamanager.scraper.http.Url:232 - getting https://ssl.google-analytics.com/collect?v=1&tid=UA-35564534-5&cid=0ce5fad1-5c09-4977-844b-4791cb92d4b2&an=tinyMediaManager&av=2.8.2&t=event&ec=startup&ea=startup&aip=1&je=1&sc=start&ul=fr-FR&vp=1631x1026&cd1=Linux&cd2=amd64&cd3=1.7&cd4=2.8.2&cd5=0&z=1469341842891&sr=1680x1050
2016-07-24 08:30:47,774 INFO  [updateThread] org.tinymediamanager.core.UpdaterTask:67 - Checking for updates...
2016-07-24 08:30:47,788 DEBUG [updateThread] org.tinymediamanager.scraper.http.Url:232 - getting http://release.tinymediamanager.org/build/digest.txt?z=1469341847788
2016-07-24 08:30:48,107 INFO  [updateThread] org.tinymediamanager.core.UpdaterTask:150 - Already up2date :)
2016-07-24 08:30:48,141 DEBUG [main] org.tinymediamanager.ui.MainWindow:303 - update result was: false
2016-07-24 08:31:31,052 INFO  [SwingWorker-pool-4-thread-7] o.tinymediamanager.core.movie.MovieList:562 - =====================================================
2016-07-24 08:31:31,053 INFO  [SwingWorker-pool-4-thread-7] o.tinymediamanager.core.movie.MovieList:563 - Searching with scraper: tmdb, 1.4
2016-07-24 08:31:31,126 INFO  [SwingWorker-pool-4-thread-7] o.tinymediamanager.core.movie.MovieList:564 - MediaSearchOptions[type=MOVIE,query=Saint Amour,year=2016,imdbId=tt4589186,tmdbId=0,language=fr,country=France]
2016-07-24 08:31:31,126 INFO  [SwingWorker-pool-4-thread-7] o.tinymediamanager.core.movie.MovieList:565 - =====================================================
2016-07-24 08:32:11,697 INFO  [SwingWorker-pool-4-thread-2] o.tinymediamanager.core.movie.MovieList:562 - =====================================================
2016-07-24 08:32:11,698 INFO  [SwingWorker-pool-4-thread-2] o.tinymediamanager.core.movie.MovieList:563 - Searching with scraper: imdb, 1.5
2016-07-24 08:32:11,699 INFO  [SwingWorker-pool-4-thread-2] o.tinymediamanager.core.movie.MovieList:564 - MediaSearchOptions[type=MOVIE,query=Saint Amour,year=2016,imdbId=tt4589186,tmdbId=0,language=fr,country=France]
2016-07-24 08:32:11,699 INFO  [SwingWorker-pool-4-thread-2] o.tinymediamanager.core.movie.MovieList:565 - =====================================================
2016-07-24 08:32:11,700 DEBUG [SwingWorker-pool-4-thread-2] o.t.scraper.imdb.ImdbMetadataProvider:108 - search() MediaSearchOptions[type=MOVIE,query=Saint Amour,year=2016,imdbId=tt4589186,tmdbId=0,language=fr,country=France]
2016-07-24 08:32:11,710 DEBUG [SwingWorker-pool-4-thread-2] o.t.scraper.imdb.ImdbMovieParser:138 - ========= BEGIN IMDB Scraper Search for: http://www.imdb.com/find?q=tt4589186&s=tt
2016-07-24 08:32:11,726 DEBUG [SwingWorker-pool-4-thread-2] org.tinymediamanager.scraper.http.Url:232 - getting http://www.imdb.com/find?q=tt4589186&s=tt
2016-07-24 08:32:14,538 DEBUG [SwingWorker-pool-4-thread-2] o.t.scraper.imdb.ImdbMovieParser:112 - IMDB: getMetadata(imdbId): tt4589186
2016-07-24 08:32:14,540 DEBUG [pool-2-thread-1] org.tinymediamanager.scraper.http.Url:232 - getting http://www.imdb.com/title/tt4589186/combined
2016-07-24 08:32:14,546 DEBUG [pool-2-thread-2] org.tinymediamanager.scraper.http.Url:232 - getting http://www.imdb.com/title/tt4589186/plotsummary
2016-07-24 08:32:16,180 INFO  [SwingWorker-pool-4-thread-3] o.t.ui.movies.MovieChooserModel:173 - =====================================================
2016-07-24 08:32:16,180 INFO  [SwingWorker-pool-4-thread-3] o.t.ui.movies.MovieChooserModel:174 - Scraper metadata with scraper: imdb, 1.5
2016-07-24 08:32:16,182 INFO  [SwingWorker-pool-4-thread-3] o.t.ui.movies.MovieChooserModel:176 - MediaScrapeOptions[result=MediaSearchResult[providerId=imdb,url=<null>,title=Saint Amour,year=2016,originalTitle=<null>,id=<null>,score=1.0,imdbId=tt4589186,type=MOVIE,posterUrl=http://ia.media-imdb.com/images/M/MV5BYjEwYTFiNTktOTdjNy00NDE3LWEzODUtZDYzODA4YTFmYzIzXkEyXkFqcGdeQXVyNTYwMzk4MjM@._V1_UY200_AL_.jpg],ids={},type=MOVIE,artworkType=ALL,language=fr,country=France,fanartSize=Moyen: ~1280x720px,posterSize=Moyen: ~342x513px]
2016-07-24 08:32:16,183 INFO  [SwingWorker-pool-4-thread-3] o.t.ui.movies.MovieChooserModel:177 - =====================================================
2016-07-24 08:32:16,184 DEBUG [SwingWorker-pool-4-thread-3] o.t.scraper.imdb.ImdbMetadataProvider:89 - getMetadata() MediaScrapeOptions[result=MediaSearchResult[providerId=imdb,url=<null>,title=Saint Amour,year=2016,originalTitle=<null>,id=<null>,score=1.0,imdbId=tt4589186,type=MOVIE,posterUrl=http://ia.media-imdb.com/images/M/MV5BYjEwYTFiNTktOTdjNy00NDE3LWEzODUtZDYzODA4YTFmYzIzXkEyXkFqcGdeQXVyNTYwMzk4MjM@._V1_UY200_AL_.jpg],ids={},type=MOVIE,artworkType=ALL,language=fr,country=France,fanartSize=Moyen: ~1280x720px,posterSize=Moyen: ~342x513px]
2016-07-24 08:32:16,185 DEBUG [SwingWorker-pool-4-thread-3] o.t.scraper.imdb.ImdbMovieParser:92 - IMDB: getMetadata from cache: MediaSearchResult[providerId=imdb,url=<null>,title=Saint Amour,year=2016,originalTitle=<null>,id=<null>,score=1.0,imdbId=tt4589186,type=MOVIE,posterUrl=http://ia.media-imdb.com/images/M/MV5BYjEwYTFiNTktOTdjNy00NDE3LWEzODUtZDYzODA4YTFmYzIzXkEyXkFqcGdeQXVyNTYwMzk4MjM@._V1_UY200_AL_.jpg]
2016-07-24 08:32:16,196 DEBUG [SwingWorker-pool-4-thread-6] org.tinymediamanager.scraper.http.Url:232 - getting http://ia.media-imdb.com/images/M/MV5BYjEwYTFiNTktOTdjNy00NDE3LWEzODUtZDYzODA4YTFmYzIzXkEyXkFqcGdeQXVyNTYwMzk4MjM@._V1_UY200_AL_.jpg
2016-07-24 08:32:53,664 ERROR [main] o.t.c.m.c.MovieToXbmcNfoConnector:494 - setData /run/user/1000/gvfs/smb-share:server=openelec,share=intenso/Films/Saint Amour (2016)/Saint Amour (2016) h264-480p AAC-2ch.nfo
java.nio.file.NoSuchFileException: /run/user/1000/gvfs/smb-share:server=openelec,share=intenso/Films/Saint Amour (2016)/Saint Amour (2016) h264-480p AAC-2ch.nfo
    at org.tinymediamanager.core.Utils.writeStringToFile(Utils.java:1313)
    at org.tinymediamanager.core.movie.connector.MovieToXbmcNfoConnector.writeNfoFiles(MovieToXbmcNfoConnector.java:488)
    at org.tinymediamanager.core.movie.connector.MovieToXbmcNfoConnector.setData(MovieToXbmcNfoConnector.java:209)
    at org.tinymediamanager.core.movie.entities.Movie.writeNFO(Movie.java:1337)
    at org.tinymediamanager.core.movie.entities.Movie.setMetadata(Movie.java:951)
2016-07-24 08:32:53,673 ERROR [main] o.t.c.m.c.MovieToXbmcNfoConnector:494 - setData /run/user/1000/gvfs/smb-share:server=openelec,share=intenso/Films/Saint Amour (2016)/movie.nfo
java.nio.file.NoSuchFileException: /run/user/1000/gvfs/smb-share:server=openelec,share=intenso/Films/Saint Amour (2016)/movie.nfo
2016-07-24 08:32:53,720 INFO  [main] o.t.core.movie.MovieRenamer:208 - Renaming movie: Saint Amour
2016-07-24 08:32:53,721 DEBUG [main] o.t.core.movie.MovieRenamer:209 - movie year: 2016
2016-07-24 08:32:53,721 DEBUG [main] o.t.core.movie.MovieRenamer:210 - movie path: /run/user/1000/gvfs/smb-share:server=openelec,share=intenso/Films/Saint Amour (2016)
2016-07-24 08:32:53,721 DEBUG [main] o.t.core.movie.MovieRenamer:211 - movie isDisc?: false
2016-07-24 08:32:53,721 DEBUG [main] o.t.core.movie.MovieRenamer:212 - movie isMulti?: false
2016-07-24 08:32:53,722 DEBUG [main] o.t.core.movie.MovieRenamer:216 - path expression: $T ($Y)
2016-07-24 08:32:53,722 DEBUG [main] o.t.core.movie.MovieRenamer:217 - file expression: $T ($Y) $V $A
2016-07-24 08:32:53,728 DEBUG [main] o.t.core.movie.MovieRenamer:353 - Our new basename for renaming: Saint Amour (2016) h264-480p AAC-2ch
2016-07-24 08:32:53,730 ERROR [main] o.t.core.movie.MovieRenamer:1220 - error moving file
    at sun.nio.fs.UnixFileSystemProvider.createDirectory(UnixFileSystemProvider.java:383)
    at java.nio.file.Files.createDirectory(Files.java:630)
    at org.tinymediamanager.core.movie.MovieRenamer.moveFile(MovieRenamer.java:1208)
    at org.tinymediamanager.core.movie.MovieRenamer.renameMovie(MovieRenamer.java:399)
    at org.tinymediamanager.core.movie.entities.Movie.setMetadata(Movie.java:956)
2016-07-24 08:32:53,846 INFO  [main] o.t.core.movie.MovieRenamer:544 - Cleanup...
2016-07-24 08:32:53,859 ERROR [tmmpool-unnamed-task-thread-1] org.tinymediamanager.Log4jBackstop:37 - Uncaught exception in thread: tmmpool-unnamed-task-thread-1
    at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
    at java.lang.Thread.run(Thread.java:745)
2016-07-24 08:32:53,863 DEBUG [tmmpool-unnamed-task-thread-2] o.t.scraper.ofdb.OfdbMetadataProvider:620 - getTrailers() MediaScrapeOptions[result=<null>,ids={tmdb=0, imdb=tt4589186},type=MOVIE,artworkType=ALL,language=fr,country=France,fanartSize=Moyen: ~1280x720px,posterSize=Moyen: ~342x513px]
2016-07-24 08:32:53,874 DEBUG [tmmpool-unnamed-task-thread-2] org.tinymediamanager.scraper.http.Url:232 - getting http://www.ofdb.de/view.php?page=suchergebnis&Kat=IMDb&SText=tt4589186
2016-07-24 08:32:55,855 DEBUG [tmmpool-unnamed-task-thread-2] o.t.scraper.ofdb.OfdbMetadataProvider:674 - found 1 search results
2016-07-24 08:32:55,855 DEBUG [tmmpool-unnamed-task-thread-2] o.t.scraper.ofdb.OfdbMetadataProvider:677 - get (trailer) details page
2016-07-24 08:32:55,858 DEBUG [tmmpool-unnamed-task-thread-2] org.tinymediamanager.scraper.http.Url:232 - getting http://www.ofdb.de/film/285203,Saint-Amour
2016-07-24 08:32:56,689 ERROR [tmmpool-unnamed-task-thread-2] org.tinymediamanager.Log4jBackstop:37 - Uncaught exception in thread: tmmpool-unnamed-task-thread-2
    at org.tinymediamanager.scraper.tmdb.TmdbMetadataProvider.getTrailers(TmdbMetadataProvider.java:176)
    at org.tinymediamanager.ui.movies.MovieChooserModel$TrailerScrapeTask.run(MovieChooserModel.java:306)
