Full Version: missing 'ADD SOURCE' possibility for adding repositories
I'm new and have KODI just installed
VERSION : KODI 16.1 GIT 2016-04-24-c327c53
COMPILED APR 24 2016
to add repositories sources
Step 1: Navigate to the “File manager” tab under the “SYSTEM” menu.
Step 2: Click on the “Add source” option. ---> this seems to be missing
screen image
Is there a possibility to activate it?
First I thought that it was not longer available, but then I saw a video tutorial where it still available was on KODI 16.1.
Looks like you're not at File manager's "root", keep clicking the ".." until you're back to root, then you would see "Add source"
Did you ever figure out the problem? It's missing on mine now too. And I have the latest version. It was there yesterday, and today it's gone. Sad
And I'm also in the root. Clicking on the .. doesn't do anything.
Kodi v16.1
Screenshot
(2016-07-26, 18:11)debianFun Wrote: [ -> ]I'm new and have KODI just installed
screen image
Might be that your profile is not entitled to ad sources?
or you've disabled the 'show add source buttons' option in kodi settings
or one of these dubious repos from your screenshot fucked up your system Smile
Thank You... Somehow this is exactly what happened.. Your awesome!!! Thank you a million times over..
(2016-10-19, 01:07)ronie Wrote: [ -> ]or you've disabled the 'show add source buttons' option in kodi settings
I was going crazy man. Thanks.
