Hi guys,
I have been using my two Raspberry Pi 2 with Kodi (Xbian to be exact)
for over two years now.
In recent months I have realized a lot of files are done with the new HEVC
codec and are therefore not playable by Pi 2 (or 3 for that matter).
So, now I am searching for a new low-priced TV box, that supports Kodi
and HEVC coded files and is using as less power as a Pi (or less).
Which one for under 40 (or 50) bucks would you recommend? The OS
does not matter, as long as there is a strong community with developing
Kodi behind it.
Thanks, guys.
Might be worth trying a Milhouse nightly build on the pi.
The HEVC will be better. You should find 8-bit 720p HEVC plays well.
An overclocked Pi3 can play most 8-bit 1080p HEVC.
(2016-07-27, 13:13)KoopaTroopa Wrote: [ -> ]Start here first, great thread
or
try this budget box thread
You're bound to find that suits your needs
Thanks, the NexBox MXQ Pro seems to be promising.
(2016-07-27, 14:20)popcornmix Wrote: [ -> ]Might be worth trying a Milhouse nightly build on the pi.
Interesting, do you have a link for that?
Just be aware, these dirt cheap AMLogic Android boxes have been having issues with AC3 Audio in Android, plus a whole bunch of other problems.
You get what you pay for.
http://forum.kodi.tv/showthread.php?tid=235305
Just looking at Tech Specs alone will fool you into buying some unsupported piece of crap. A LOT of people get fooled by marketing and tech specs.
And here is a BIG warning. These cheap, unsupported AML Android boxes are going to be next to useless if AMLogic don't get their act together before Kodi Krypton is released.
Cheap Android is a damn Minefield !!!
If its just Kodi you want run on the the device, seriously just get an ODROID C2. It will run rings around the RPi's for playing 1080p/2160p HEVC.
OR look in the
Budget AML S905 thread for a device that runs LibreELEC Kodi + HEVC well.
Don't buy any AMLogic S905 not mentioned in that thread.
(2016-07-27, 16:15)wrxtasy Wrote: [ -> ]Just be aware, these dirt cheap AMLogic Android boxes have been having issues with AC3 Audio in Android, plus a whole bunch of other problems.
OR look in the Budget AML S905 thread for a device that runs LibreELEC Kodi + HEVC well.
I bought now that NexBox MXQ Pro and hope, I am able to
get LibreELEC on it. I never used anything else than Xbian,
which has an easy and detailed approach. So, I hope, this
will be the same.
Unfortunately, those two links towards LibreELEC for the
NexBox MXQ Pro lead to a forum, which needs a registered
account and when I tried that (over ten times), I did get the
message: You did not answer the verification questions correctly.
But, of course, I filled it in correctly.
(2016-07-27, 16:15)wrxtasy Wrote: [ -> ]Cheap Android is a damn Minefield !!!
True that... and speaking of
that thread, any boxes I should add/remove from post #1?
(2016-07-27, 17:18)syco Wrote: [ -> ]I bought now that NexBox MXQ Pro and hope, I am able to
will be the same.
Since that forum often has technical issues I'm gonna qoute here post for OE build for Nexbox MXQ Pro.
Quote:another openelec build for nexbox mxq pro 4k, based on version for SPOT_i7 from 150balbes
https://mega.nz/#F!OMEH1LIB!VyloBDvKVvCk4OXFBa5fAA
can work from flash/sd
power button dont work
(2016-07-27, 15:22)syco Wrote: [ -> ] (2016-07-27, 13:13)KoopaTroopa Wrote: [ -> ]Start here first, great thread
or
There's a sticky thread in the Pi subforum.
(2016-07-27, 14:20)popcornmix Wrote: [ -> ]An overclocked Pi3 can play most 8-bit 1080p HEVC.
This is too vague to describe decoding capability.
Most what? Most of your personally encoded videos? Most from some torrent site/group?
Pi3 HEVC decoding capability is extremely weak and it will only play 'most' 1080p HEVC videos if your test pool comprises very low bitrate/complexity files.
Nobody should be recommending that people buy a RPi if HEVC is a requirement. If you already have one....sure, by all means try to squeeze the most from it. But when someone posts a thread asking for HEVC-capable recommendations, please don't say "RPi can play most 1080p HEVC". It's simply not true.
(2016-07-28, 16:08)voochi Wrote: [ -> ]Nobody should be recommending that people buy a RPi if HEVC is a requirement. If you already have one....sure, by all means try to squeeze the most from it. But when someone posts a thread asking for HEVC-capable recommendations, please don't say "RPi can play most 1080p HEVC". It's simply not true.
The original poster did mention he had a Pi and wasn't using a build that has the best HEVC performance, so it's worth a try.
But, yes, I agree, if HEVC is your main requirement and you need to buy a new device, then getting something with HW HEVC support is obviously the best option.
Popq
Sent from my SM-G361H
(2016-07-29, 03:07)jonas.wange Wrote: [ -> ]Popq
Wtf? What is that? Google told me nothing.
(2016-07-27, 19:36)bobrooney Wrote: [ -> ]Since that forum often has technical issues I'm gonna qoute here post for OE build for Nexbox MXQ Pro.
Thanks for the link to the img file, but can you also show
me a step-to-step tutorial what to do with it?
Sorry, never
have done something like that. With my Pis and Xbian I
used an easy installer.
