2016-08-10, 18:02
Hi.
I use a machine (backend) with Mediaportal TV server and Kodi too. Everything is fine on there.
I recently tried to setup another pc to have Kodi as a frontend for liveTV (tried on windows and linux machine). Both same results. Connection lost pop-up, no pvr client started (when selecting live tv in kodi) etc...
I have those version installed on my backend machine.
+ TV server : 1.15
+ TVServerKodi DLL : 1.15.034
+ Kodi : Jarvis 16.1
+ Mediaportal PVR Client : 1.13
I will not copy a complete log file, but here is the suspicious part, I think.
11:20:42 T:2060 NOTICE: PVRManager - starting up
11:20:42 T:6284 NOTICE: Running the application...
11:20:42 T:6284 NOTICE: starting zeroconf publishing
11:20:42 T:6284 NOTICE: WebServer: Started the webserver
11:20:42 T:6284 NOTICE: starting upnp client
11:20:42 T:6284 NOTICE: starting upnp server
11:20:42 T:6284 NOTICE: starting upnp renderer
11:20:42 T:5056 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
11:20:42 T:5056 NOTICE: UDP: Listening on port 9777
11:20:56 T:6284 ERROR: Unable to activate the previous window
11:21:03 T:1464 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect 192.168.1.43:9596
11:21:03 T:1464 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect: (Winsock error=10060) Connection timed out
11:21:03 T:1464 ERROR: AddOnLog: MediaPortal PVR Client: Could not connect to MediaPortal TV Server backend
11:21:03 T:1464 ERROR: ADDON: Dll MediaPortal PVR Client - Client returned bad status (1) from Create and is not usable
11:21:03 T:1464 WARNING: PVR::CPVRClients::UpdateAndInitialiseClients - failed to create add-on MediaPortal PVR Client, status = 1
11:21:24 T:1464 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect 192.168.1.43:9596
11:21:24 T:1464 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect: (Winsock error=10060) Connection timed out
11:21:24 T:1464 ERROR: AddOnLog: MediaPortal PVR Client: Could not connect to MediaPortal TV Server backend
11:21:24 T:1464 ERROR: ADDON: Dll MediaPortal PVR Client - Client returned bad status (1) from Create and is not usable
11:21:24 T:1464 WARNING: PVR::CPVRClients::UpdateAndInitialiseClients - failed to create add-on MediaPortal PVR Client, status = 1
11:21:46 T:1464 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect 192.168.1.43:9596
11:21:46 T:1464 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect: (Winsock error=10060) Connection timed out
11:21:46 T:1464 ERROR: AddOnLog: MediaPortal PVR Client: Could not connect to MediaPortal TV Server backend
11:21:46 T:1464 ERROR: ADDON: Dll MediaPortal PVR Client - Client returned bad status (1) from Create and is not usable
11:21:46 T:1464 WARNING: PVR::CPVRClients::UpdateAndInitialiseClients - failed to create add-on MediaPortal PVR Client, status = 1
11:22:08 T:1464 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect 192.168.1.43:9596
11:22:08 T:1464 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect: (Winsock error=10060) Connection timed out
11:22:08 T:1464 ERROR: AddOnLog: MediaPortal PVR Client: Could not connect to MediaPortal TV Server backend
11:22:08 T:1464 ERROR: ADDON: Dll MediaPortal PVR Client - Client returned bad status (1) from Create and is not usable
11:22:08 T:1464 WARNING: PVR::CPVRClients::UpdateAndInitialiseClients - failed to create add-on MediaPortal PVR Client, status = 1
11:22:30 T:1464 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect 192.168.1.43:9596
11:22:30 T:1464 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect: (Winsock error=10060) Connection timed out
11:22:30 T:1464 ERROR: AddOnLog: MediaPortal PVR Client: Could not connect to MediaPortal TV Server backend
11:22:30 T:1464 ERROR: ADDON: Dll MediaPortal PVR Client - Client returned bad status (1) from Create and is not usable
11:22:30 T:1464 WARNING: PVR::CPVRClients::UpdateAndInitialiseClients - failed to create add-on MediaPortal PVR Client, status = 1
11:22:49 T:6284 NOTICE: Storing total System Uptime
11:22:49 T:6284 NOTICE: Saving settings
11:22:49 T:6284 NOTICE: stop all
11:22:49 T:6284 NOTICE: stop player
11:22:49 T:6284 NOTICE: PVRManager - stopping
11:22:53 T:1464 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect 192.168.1.43:9596
11:22:53 T:1464 ERROR: AddOnLog: MediaPortal PVR Client: Socket::connect: (Winsock error=10060) Connection timed out
11:22:53 T:1464 ERROR: AddOnLog: MediaPortal PVR Client: Could not connect to MediaPortal TV Server backend
11:22:53 T:1464 ERROR: ADDON: Dll MediaPortal PVR Client - Client returned bad status (1) from Create and is not usable
11:22:53 T:1464 WARNING: PVR::CPVRClients::UpdateAndInitialiseClients - failed to create add-on MediaPortal PVR Client, status = 1
Thanks in advance!
+ TV server : 1.15
Thanks in advance!
