Full Version: Best Windows PVR IPTV Backend
Hi there, I am using IPTV service from my internet provider, but the IPTV streams are on a different network, so I need 2 ethernet adapters on 1 PC (one to catch the IPTV stream from modem and then re-stream it into local network), thats why I can´t use IPTV Simple client. So I am asking what is the best Windows PVR Backend with IPTV support. Mainly I need fast channel switching. I don´t care if the setup process is more complicated on one solution than on the other. I heard about DVBLink or DVBViewer. But maybe there are other, better alternatives. What would you reccommend? Blush
Maybe I should simplify the question, If anyone else tried DVBViewer and DVBLink, which of these two would you recommend? Smile
