Full Version: comskip with jarvis
Hi!
I've recently upgraded my kodi clients to Jarvis 16.1 and the mediaportal back end to the latest 1.x add on.
I'm still having problems with comskip that I was a year or so ago with the older versions...
" If I use the skip forward or backward buttons (up, down, left and right arrow keys) then instead of skipping forward or backwards 10 seconds, or 10 minutes etc it gets confused and skips much larger amounts depending on how many sets of adverts have been shown.
In fact after a set of adverts it pretty much becomes impossible to skip backwards as it jumps forwards despite pressing the left arrow?!
If I delete the .edl then skipping back and forth works fine but no advert skipping takes place during playback...
If I left the program play fully then ad skipping works great.."
Is the problem deep rooted in Kodi and not the mediaportal add on and so is unable to be fixed?
I've found the solution, must search harder next time!
http://forum.kodi.tv/showthread.php?tid=...pid2399702
http://kodi.wiki/view/Edl
