Full Version: Playing Live TV Recordings from vBox XTi-3342
Hello,
I have recently setup a vBox XTi-3342, using an external USB drive and Kodi 16.1 for watching / recording live TV.
All seems to work well, (especially now I have worked out how to setup channel pairing for the HD channels), with the exception of playing back recordings.
If I try to play a recording a 'working' message appears in the bottom right hand corner for < 1 second and then nothing else happens.
Having looked at the logfile the I have the following message:
11:33:26 T:11752 NOTICE: DVDPlayer: Opening: http://192.168.1.242:55555/Media/The Simpsons__Channel 4__24-08-2016_11-00.mpg
11:33:26 T:11752 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
11:33:26 T:12112 NOTICE: Creating InputStream
11:33:27 T:12112 ERROR: CCurlFile::Open failed with code 404 for http://192.168.1.242:55555/Media/The Simpsons__Channel 4__24-08-2016_11-00.mpg
11:33:27 T:12112 ERROR: XFILE::CFileCache::Open - failed to open source <http://192.168.1.242:55555/Media/The Simpsons__Channel 4__24-08-2016_11-00.mpg>
11:33:27 T:12112 ERROR: CDVDPlayer::OpenInputStream - error opening [http://192.168.1.242:55555/Media/The Simpsons__Channel 4__24-08-2016_11-00.mpg]
11:33:27 T:12112 NOTICE: CDVDPlayer::OnExit()
11:33:27 T:11752 NOTICE: CDVDPlayer::CloseFile()
11:33:27 T:11752 NOTICE: DVDPlayer: waiting for threads to exit
11:33:27 T:11752 NOTICE: DVDPlayer: finished waiting
If I paste the above URL into a browser, I can download the file and it plays fine. I can also access the recordings by adding the vBox as a UPNP device in the video section of Kodi, which gets round the problem to a certain extent, but I'd like it to work in the 'recordings' menu.
I have Kodi installed on Windows 10, Android 6 and a Fire stick and the same error occurs across the devices.
I have worked through the menus and other forum posts to try and resolve it but have had no joy.
Any thoughts / suggestions would be greatly appreciated.
Hi @LincsCT we have found that some Unicode text are not translated correctly by Kodi and have developed a fix
You can download the new beta FW from the following link http://goo.gl/l2VxsB
Thank you @VBox, this has fixed the problem completely.
Excellent product - 1 very happy customer here.
VBOX: I have an XTi3334 (unicable). I also have the problem with playing recorded programmes via the TV section of Kodi. I downloaded your software update, but after it gave me a warning that all streams would stop and the box would restart after install, it then said that this update was not compatible with my box
Branksome: best to contact VBox support directly by email ([email protected]) for the latest v2.55 firmware.
