2016-08-29, 23:21
Hello,
I can not succeed to connect MediaPortal PVRClient on Kodi installed on a raspberry pi 3.
My configuration is:
SERVER
* Windows 7
* Media portal 1.15.0
CLIENT 1
* Windows 10
* Kodi 16.1 (Apr 24 2016)
* MediaPortal PVRClient 1.13.6
CLIENT 2
* Raspberry PI 3
* Rasbian jessie (kernel linux 4.4.13-v7+)
* MediaPortal PVRClient 1.12.0
On client 1, all is OK, I can see the TV on Kodi.
But on client 2, no way to connect PVRClient to server. I read a lot of posts on forum but without result.
I can connect to the shared folder (for example in file manager).
I try to disable windows firewall (on server side) but this changes nothing.
Do you have any idea to solve my problem?
For information, here is a sample of the log file:
Thanks in advance,
Laurent
SERVER
* Windows 7
CLIENT 1
* Windows 10
CLIENT 2
* Raspberry PI 3
21:48:46 1214.746460 T:1762358192 ERROR: AddOnLog: MediaPortal PVR Client: Socket::setHostname: (errno=0) (null)
21:48:46 1214.746582 T:1762358192 ERROR: AddOnLog: MediaPortal PVR Client: Socket::setHostname(HTPC-PC) failed.
21:48:46 1214.746704 T:1762358192 ERROR: AddOnLog: MediaPortal PVR Client: Could not connect to MediaPortal TV Server backend
21:48:46 1214.748413 T:1762358192 ERROR: ADDON: Dll MediaPortal PVR Client - Client returned bad status (1) from Create and is not usable
21:48:46 1214.750488 T:1762358192 WARNING: UpdateAndInitialiseClients - failed to create add-on MediaPortal PVR Client, status = 1
Thanks in advance,
Laurent
