2016-09-11, 11:38
2016-09-11, 11:38
2016-09-11, 12:03
false
2016-09-11, 12:31
2016-09-11, 12:33
(the goal is to remove the "Test" label on the top left tile)
2016-09-11, 17:01
if you leave the label empty and remove the fallback that should work (line 1693)
2016-09-11, 18:31
2016-09-11, 18:38
PHP Code:
<control type="radiobutton" id="2403">
<include>SettingsCustomDialogRadioButtonVars</include>
<label>$LOCALIZE[31156]</label>
<onclick condition="IsEmpty(Window.Property(HomeTileEdit.ShowLabel))">Skin.SetString($INFO[Window.Property(HomeTileEdit)].ShowLabel,on)</onclick>
<onclick condition="IsEmpty(Window.Property(HomeTileEdit.ShowLabel))">SetProperty(HomeTileEdit.ShowLabel,on)</onclick>
<onclick condition="!IsEmpty(Window.Property(HomeTileEdit.ShowLabel))">Skin.Reset($INFO[Window.Property(HomeTileEdit)].ShowLabel)</onclick>
<onclick condition="!IsEmpty(Window.Property(HomeTileEdit.ShowLabel))">ClearProperty(HomeTileEdit.ShowLabel)</onclick>
<selected>!IsEmpty(Window.Property(HomeTileEdit.ShowLabel))</selected>
</control>
2016-09-12, 21:37
I fixed it by removing the following part, but it removes all labels at the current page
PHP Code:
<control type="group">
<visible>[!IsEmpty(ListItem.property(showlabel)) + !IsEmpty(ListItem.Property(Path))] | [IsEmpty(ListItem.Property(Path)) + IsEmpty(ListItem.Property(custom))]</visible>
<control type="image">
<posx>24</posx>
<posy>241</posy>
<width>283</width>
<height>66</height>
<texture border="1">windows/home/tile-overlay.png</texture>
<colordiffuse>99FFFFFF</colordiffuse>
</control>
<control type="label">
<posx>24</posx>
<posy>241</posy>
<width>283</width>
<height>66</height>
<label>$INFO[ListItem.Label]</label>
<font>Font-Condensed-S33</font>
<textcolor>aawhite</textcolor>
<align>left</align>
<aligny>center</aligny>
<textoffsetx>20</textoffsetx>
</control>
</control>
PHP Code:
<posx>24</posx>
<posy>241</posy>
<width>283</width>
<height>66</height>
</control>
<posx>24</posx>
<posy>241</posy>
<width>283</width>
<height>66</height>
<align>left</align>
</control>
</control>
2016-09-12, 21:38
Would still be good to know the negative value, maybe it is effected by my langueage settings?
2016-09-13, 08:47
check if an empty string for showlabel works or look at the code where skin string is set.
