hi guys
Does anyone know if it possible or a way to change a widgets source/string (what it displays) via a
RunScript or
ExecuteBuiltin command using the Xonfluence skin. Or by any other method?
Im trying to make it so that when i click on individual add-on shortcuts on the homescreen the widget will change to display a specified source/folder.
I was thinking of a
RunScript or
ExecuteBuiltin command as i can do this via a
Manual Entry within Super Favourites, and then set that as the add-on shortcut.
Within Kodi in the Xonfluence skin the custom widget source/string is displayed and edited in the settings.
In my external Kodi files (
kodi/userdata/addon_data/skin.xonfluence/settings.xml) my widget source/string is defined as:
<setting id="HomeItem.8.Widget" type="string">XXXX</setting>
with XXXX being my source/string (mine being plugin://plugin.program.super.favourites/...).
I've had a read and from what i can understand I could edit this file with a Python script, that would be activated by a Super Favourite
RunScript command, but I've tried manually editing it with Kodi running and it doesn't change/work, not sure why
so don't think thats an option.
Thanks for reading and any help or advice would be much appreciated
Kodi loads the skin at startup so if you edit a string like that, you would need to reload the skin to see the changes. If however you use a window property that you can display with $INFO[Window(home).Property(myproperty)] then that will update with every render pass.
You can easily create and set window properties with a python script.
hi mate, thanks for your reply, really appreciated.
Quote:Kodi loads the skin at startup so if you edit a string like that, you would need to reload the skin to see the changes.
Just been having a play around with it then:
- With Kodi running, I manually edited the settings.xml and ran ReloadSkin() command via ExecuteBuiltIn and it blinks/flashes as if its doing something but still shows previous widget
- With Kodi closed, if I edit the settings.xml and then re-open Kodi it shows my new widget
Not sure if the
ReloadSkin() is not working or whether the skin is caching/saving elsewhere after it loads, and is then reading from there rather than from the
settings.xml file
Quote:If however you use a window property that you can display with $INFO[Window(home).Property(myproperty)] then that will update with every render pass.
I've not come across that before
(quite new to the workings of kodi and scripting/python in general!) will have a read up on it now. Is it similar to an
ActivateWindow or is it still via a widget?
thanks again
danny
A window property is something that you can define in a python script running inside of Kodi. Lots of scripts use this to send info to skins that they wouldn't otherwise be able to display. There are also a bunch of pre-defined window properties.
http://kodi.wiki/view/InfoLabels (see section 17 in particular).
So, in a python script you can do this
PHP Code:
window = xbmcgui.Window(10000) # thats the Home window
window.setProperty("myproperty","My Value")
Then in your skin you do
PHP Code:
<control type="label">
<label>$INFO[Window(Home).Property(myproperty)]</label>
</control>
That would display My Value
When the script updates myproperty, then that will be reflected on screen.
This isn't the easiest thing to get your head around to start with as it involves some skinning knowledge as well as python but it's extremely powerful and flexible as it allows you to display and change exactly what you want. Scripts can be started and stopped when a window opens (with onload and onunload tags in the skin) or can be made to run when Kodi starts. All this stuff is in the wiki but it does take a bit of digging around to link it all up !!
(2016-09-11, 22:38)black_eagle Wrote: [ -> ]A window property is something that you can define in a python script running inside of Kodi. Lots of scripts use this to send info to skins that they wouldn't otherwise be able to display. There are also a bunch of pre-defined window properties. http://kodi.wiki/view/InfoLabels (see section 17 in particular).
PHP Code:
PHP Code:
</control>
hi mate, thanks for getting back to me
couldn't get it working via the
Window Property, not for the love of trying either
still don't know what I'm doing wrong!
Had a good read through the wiki page just got really confused! I find the wiki is quite hit n miss a lot of the time, i think it requires a certain level of knowledge/understanding - that i don't have! Haha
But when i was looking through the Xonfluence source code for the $INFO[Window(Home) functions i came across the Skin.SetString commands that got it working in the end
have posted it below.
thanks again for your help mate
danny
WORKING!!!!
Below is how i got Add-On shortcuts on my home menu to each have there own different widgets, meaning you can get upto 7 widgets on one HomeMenu within Xonfluence.
It does require writing individual scripts.py for each widget, and there is probably a much better and easier way to do this, but having searched the forums and google (a lot) I couldn't find one, and it's nice and easy, so thought id share it...
I made a python script (SCRIPT1.py) with text editor/notepad, containing the code below and saved it in the Super Favourites Userdata folder located at
/userdata/addon_data/plugin.program.super.favourites/
PHP Code:
import xbmc
cmd = 'Skin.SetString(HomeItem.1.Widget, XXXX)'
xbmc.executebuiltin(cmd)
cmd = 'ClearProperty(HomeItem.1, Home)'
XXXX being the source/string to display. In my case a Super Favourite folder so
I then used
Manual Entry in Super Favourites to make a
RunScript to run the command below:
Special://home/userdata/addon_data/plugin.program.super.favourites/SCRIPT1.py
added a thumbnail to the created Super Favourite, and added it to my Kodi favourites, and added that Kodi favourite to my Add-Ons shortcuts menu in settings.
Now when i click on my customised Super Favourite Add-On's along the bottom on my home screen, they each show different widgets
With the 12 individual Add-On sets available in Xonfluence thats up to 84 widgets!
(2016-09-12, 03:41)dannyrobbo Wrote: [ -> ]With the 12 individual Add-On sets available in Xonfluence thats up to 84 widgets!
...but would mean 84 individual scripts
If anyone knows how i could make it easier/faster it would be really appreciated
thanks for reading
I would think the easiest way would be to change the main menu to use skin shortcuts.
Then build the widgets using templates. It does take a lot to get you head around how to go about it but skin shortcuts is well documented.
If you take a look at the code for Madnox and Nox Silvo it should give you some ideas. It did take me a number of months for me to understand and develop the widgets for both these skins. It is rather complicated code but could be simplified for less features.
The other method would be look take a look at how estuary is coded. 5 widgets per menu item that is a simple and clever solution.
(2016-09-12, 03:44)dannyrobbo Wrote: [ -> ] (2016-09-12, 03:41)dannyrobbo Wrote: [ -> ]With the 12 individual Add-On sets available in Xonfluence thats up to 84 widgets!
thanks for reading
Hi Dannyrobbo,
I'm trying to recreate what you did here...but it hasn't worked for me. Whenever I click on the addon shortcut on the home page, it takes me to an empty list, even though the SF folder the python script points to has favourites in it.
I'm using SuperFavourites 1.0.59 and Xonfluence 9.99.99 from the 'Helly' repo.
Can you help me figure out what I've done wrong?
thanks for reading
Hi Dannyrobbo,
