2016-09-13, 11:15
hi again @jingai
Very much loving the work going in to the new skin, been very impressed with how smooth it is and the extra functions you are building in. I have been pondering on a couple of bits and wondering if I could make a couple cheeky requests for your consideration.
Atmos / DTS-X codec flag
Within the skin there are various area where codec flags are displayed.. would it be possible to add a simple filnename variable along the lines of .atmos. and .dtsx to allow for those codecs flags to be displayed. Kodi doesn't recongnise them natively as they are simple TrueHD or DTS-HD tracks with additional meta data.
I have used this in the past...
<variable name="MediaFlag_AudioCodec">
<value condition="IsEmpty(ListItem.AudioCodec)">$INFO[VideoPlayer.AudioCodec,flags/AudioCodec/,.png]</value>
<value condition="SubString(ListItem.Filenameandpath,.atmos.)">flags/audiocodec/atmos.png</value>
<value condition="SubString(ListItem.Filenameandpath,.dtsx.)">flags/audiocodec/dtsx.png</value>
<value>$INFO[ListItem.AudioCodec,flags/AudioCodec/,.png]</value>
</variable>
Then added .atmos or .dtsx to the filepath in the same way you would 3D etc.
Along the same would be the 3D flag.. am struggling myself with this one and am wondering if its just a simple case of renaming all my files... and adding 3D at the end.. am not a big fan of asking for something to be added for the sake of it! The only way I could think of is to use a resolution variable and add a additional flag.
</variable>
