2016-09-18, 21:41
Im currently running Kodi Krypton on FireTV. When I go into PVR setup the NEXTPVR is not an option. Has anyone figured this out? Would hate to have to downgrade Kodi. Krypton is an major improvement.
(2016-09-18, 21:41)Bryangauvin Wrote: [ -> ]IHas anyone figured this out?I have had NextPVR installed and running on one of my computers, using Krypton Beta 1. I'm not sure what I did, as I remember it, it was very straightforward, I enabled an addon in Kodi after installing the NextPVR program. Just looking at it now, if you go to Settings/System, then Add-ons, then "Running" (mine's empty) then go up from there (press the 2 dot symbol), then My Addons, there's a list of addons to enable. I don't recall having to install it myself, I think I just enabled it from that list. (Yes, the location of those addons seems a bit "weird", I'm not sure where they are, but that's where I found them)
(2016-09-18, 21:41)Bryangauvin Wrote: [ -> ]Im currently running Kodi Krypton on FireTV. When I go into PVR setup the NEXTPVR is not an option. Has anyone figured this out? Would hate to have to downgrade Kodi. Krypton is an major improvement.
