Was away for little . Plz which is better and more stable for the Apple TV 4
Kodi 17-alpha2. May 22. Or. one of the latest built.
Thank you
(2016-09-21, 06:22)panny Wrote: [ -> ]Alpha 3 - July 30 build
thank you for your answer
(2016-09-21, 18:09)Japgeisha Wrote: [ -> ] (2016-09-21, 06:22)panny Wrote: [ -> ]Alpha 3 - July 30 build
You're welcome
Got my Apple TV 4 yesterday.
Comes with Ios 10
Is the Alpha 3 - July 30 build the best way to go too with IOS 10 ?
Thanks for help, still a Kodi rookie...
Yes it is. Although if you're doing a clean install, people have had successes with beta 1.
Try beta 1 and worst case scenario, you have to install Alpha 3 over the top because beta 1 didn't work.
Latest is great but has problem with many add ons
Becuz of dependency,,
In my experience July 31st build has been the most solid yet. Will stick to that one until a new build is out that works with advanced settings xml properly
(2016-09-25, 19:20)chrisjohnson83 Wrote: [ -> ]In my experience July 31st build has been the most solid yet. Will stick to that one until a new build is out that works with advanced settings xml properly
you are right i tried july 30th and its fabulous.
anyone tried the latest built compare to july 30 . thx
so even the 10/10 build is no good ?[/align]
10/10 is not great either has lot of failed dependency not updating the url resolver too bad . hope they fix it in the coming one . july 30 is still rock solid .
