Full Version: TVDB Scrapper only Showing Season 1
since i upgraded to Kodi 16 (from Kodi 15.2) the TVDB Scrapper is only Showing Season 1 for some TV Shows (mostly Comic/Anime Shows). Can't figure out why this is.
Here a Log extragt with Debuging on for one Episode i serched
22:00:37 T:139770884196416 DEBUG: LIRC: Update - NEW at 12943863:160 0 KEY_OK devinput (KEY_OK)
22:00:37 T:139770884196416 DEBUG: OnKey: 11 (0x0b) pressed, action is Select
22:00:37 T:139768694241024 DEBUG: webserver: request received for /jsonrpc?tm=1474660837423
22:00:37 T:139768694241024 DEBUG: webserver: request received for /jsonrpc?tm=1474660837431
22:00:38 T:139770884196416 DEBUG: ------ Window Deinit (DialogVideoInfo.xml) ------
22:00:38 T:139770884196416 DEBUG: VideoInfoScanner: No NFO file found. Using title search for '/media/Raid/Serien/Ultimate Spider-Man/Season.04/Der.ultimative.Spider-Man.S04E09.mkv'
22:00:38 T:139770884196416 DEBUG: DialogProgress::Open called
22:00:38 T:139770884196416 DEBUG: ------ Window Init (DialogProgress.xml) ------
22:00:38 T:139770884196416 DEBUG: VideoInfoScanner: Found episode match /media/Raid/Serien/Ultimate Spider-Man/Season.04/Der.ultimative.Spider-Man.S04E09.mkv (s4e9) [s([0-9]+)[ ._-]*e([0-9]+(?Sad?:[a-i]|\.[1-9])(?![0-9]))?)([^\\/]*)$]
22:00:38 T:139770884196416 DEBUG: GetEpisodeId (/media/Raid/Serien/Ultimate Spider-Man/Season.04/Der.ultimative.Spider-Man.S04E09.mkv), query = select idEpisode from episode where idFile=21929
22:00:38 T:139770884196416 DEBUG: GetEpisodeList: Searching 'http://thetvdb.com/api/1D62F2F90030C444/series/257645/all/en.zip' using The TVDB scraper (file: '/var/lib/vdr/.kodi/addons/metadata.tvdb.com', content: 'tvshows', version: '1.8.4')
22:00:39 T:139770884196416 ERROR: PCRE: Match limit reached
22:00:39 T:139770884196416 DEBUG: scraper: GetEpisodeList returned <episodeguide><episode><id>4975821</id><title>The Return of the Guardians of the Galaxy</title><aired>2014-07-06</aired><epnum>65</ep.... (couldN't fill that line fully in, is there a way to upload log file here?...)
22:00:39 T:139770884196416 DEBUG: OnProcessSeriesFolder - no match for show: 'Ultimate Spider-Man', season: 4, episode: 9.0, airdate: '01.01.1601', title: ''
22:00:39 T:139770884196416 DEBUG: Mysql execute: update path set strHash='' where idPath=7411
22:00:39 T:139770884196416 DEBUG: GetEpisodeId (/media/Raid/Serien/Ultimate Spider-Man/Season.04/Der.ultimative.Spider-Man.S04E09.mkv), query = select idEpisode from episode where idFile=21929
22:00:39 T:139770884196416 DEBUG: ------ Window Init (DialogVideoInfo.xml) ------
22:00:39 T:139770884196416 DEBUG: ------ Window Deinit (DialogProgress.xml) ------
22:00:40 T:139768694241024 DEBUG: webserver: request received for /jsonrpc?tm=1474660840427
22:00:40 T:139768628909824 DEBUG: webserver: request received for /jsonrpc?tm=1474660840428
22:00:40 T:139768628909824 DEBUG: Previous line repeats 1 times.
22:00:40 T:139768628909824 DEBUG: webserver: request received for /jsonrpc?tm=1474660840443
Complete logs only, and to a paste site please.
Complete Log is here:
https://1drv.ms/u/s!AsBYq12nbEtnpxgqpj43F69fvChG
tried to update this Episode "ultimate.spider-man.vs.the.sinister.6.s04e19.720p.hdtv.x264-w4f.mkv"
