Hi guys, I forked the Subsonic addon by basilfx, which was broken.
My first idea was just to make it work again; but I ended up rewriting a lot of the code and adding nice new features, including downloading tracks !
You can download it
here !
Enjoy...
Which features did you add? Long time refunding user here. How does this incorporate into the kodi library? @
zag this may be of interest.
Will not install.
[plugin.audio.subsonic]: The dependency on script.module.simpleplugin version 2.0.1 could not be satisfied
Pasado : fixed ! Please download v.2.0.4.
(2016-10-04, 03:22)gordie Wrote: [ -> ]Hi guys, I forked the Subsonic addon by basilfx, which was broken.
You can download it here !
Enjoy...
+1
Great work gordie, excellent work, many thanks.
Thanks! Cool!
Hey Gordie
+1
I like that Plugin a lot.
Maybe it is an good idea to make the Plugin multilanguage
I Started with it already.
gordie - would you consider submitting this add-on to the official kodi repo?
Finally found this one after the old addon stopped working, I'm glad someone rewrote it. Thanks gordie.
But I have an issue with it, I can't connect to my subsonic server. I'll suspect the addon ignoring the webroot of subsonic?
I have it run behind a reverse nginx proxy with
https://host/subsonic ... the weblogs are showing requests without the webroot.
Anyone experienced this? Or might this be a feature request on github
Edit: Just played around a little, if I add the webroot hardcoded to the connection.py of the libsonic module on line 100 (before the /rest):
serverPath='/subsonic/rest', appName='py-sonic', apiVersion=API_VERSION,
It is working for me. So I guess it's a feature request to allow for a webroot option.
It works!
First time I've tried Subsonic. Went with a Madsonic server, setting up a .madsonic.org address.
Got a couple of questions:
1. Is the traffic being routed locally?
2. How do I browse by other parameters, such as Genre or Year?
I'm sorry for the noob question, but:
I've been using running my own subsonic server for years, and have finally tried installing it on my raspbian/kodi system.
Got the plugin working, but I can't seem to figure out how to connect it to my own personal server.
I'm running raspberrypi 4.9.35-v7+ with kodi v17.3
Thank you!
gordie
addon is working great.
but how do i add this as source to my music library, i would prefer to use it that way, is that possible?
You can only use this addon with Subsonic servers or also with Airsonic?
Also interessted in Norin_Radds question, about integration of Subsonic (or Airsonic) libraries into KODI music libraries.
(2019-10-06, 12:21)Falcon_X Wrote: [ -> ]You can only use this addon with Subsonic servers or also with Airsonic?
I am also very interested in both of these questions as well. I already use Airsonic on my phone to stream my music library.
