Good evening, i just installed aeon mq 6 and i'm trying to configure it.
Now i would like to put specific add-on icon in the home menu.
How can i do it?
Up
mtguido, MQ6 and MQ7 is the same, go to settings, submenu customize main menu, use replace function choose My Menu for concentrate icons.
Populate each submenu with one addon, it´s results after customize.
Or select widget video addons (show all), press up arrow in any main menu item for open widget selector.
(2016-10-11, 02:55)Wanilton Wrote: [ -> ]@mtguido, MQ6 and MQ7 is the same, go to settings, submenu customize main menu, use replace function choose My Menu for concentrate icons.
Thanks for your replay. I follow your guide but i was just in those menu and i just edited it in that way.
Opposite i Want that addon appear like icon with their image like in your picture.
Ps. Is it possibile to update to mq7 without loosing all settings?
It´s no possible use settings MQ6 in MQ7, it´s other skin, with many others features.
And about addon icons
Press up arrow item My Menu in main menu, and choose selector widget - My Menu 1 item. Rename item My Menu 1 for any other name.
(2016-10-12, 12:53)Wanilton Wrote: [ -> ]Press up arrow item My Menu in main menu, and choose selector widget - My Menu 1 item. Rename item My Menu 1 for any other name.
Read my up post with picture
I read your previous post, after insert item in main menu, you need select widget, press Up Arrow for open widget selector, there you find My Menu 1 Item, only need select.
Perhaps a more detailed step by step explanation would help?
mtguido, please
read forum rules, don´t post images with piracy addons, edited your posts for continue fine this thread.
Perfect @Wanilton! I reached it Up!!! Thank you so much and sorry for my picture, i didn't know it was a piracy addon!
Just two more question:
Isn't possible to delete the write "my menù 1 (X)" under the widget?
I would like to try Mq 7, but I have a preinstalled xmbc on my minix android box. I think is version "kodi 15.3". I tried to install mq 7 but report error. Maybe is for the version? Can't i install on this version?
Regards
MQ7 is only for Kodi Jarvis 16.1.
It´s no possible remove My Menu 1 (X), but it´s possible rename in customize main menu. This button is used for reopen widget selector.
(2016-10-13, 03:16)Wanilton Wrote: [ -> ]MQ7 is only for Kodi Jarvis 16.1.
Can I update my xbmc or have I to install a new copy of 16.1?
