Hi mike love the mod keep up the great work!!! One question for you is there a way I can make a shortcut directly to the check for updates setting in the side menu window? I'd rather force check the system then wait you know some of us can be impatient if you know what I mean
The descriptions on the wiki (
List of built-in functions (wiki)) are somewhat vague, so these may or may not do what you want, but you could try setting the action of a shortcut to either 'UpdateAddonRepos' or 'UpdateLocalAddons'.
Thanks a lot bud I'll give it a whirl and see what I come up with. Also I've got one more question I've got a few custom menu bar that I've built in photo shop is it possible to get those in rotation with a certain theme color instead of changing the home.xml file every time. Just like the Glow zip u can install? I have the Kodi tool if that helps
