hi, i changed film background image using fanart.
now i would like to use the original film background image in another customized section. can i know the folder of the preset image to manually select it.?
thanks
Look backgrounds folder, all default images is there, inside skin.aeonmq7 folder.
(2016-10-13, 14:53)Wanilton Wrote: [ -> ]Look backgrounds folder, all default images is there, inside skin.aeonmq7 folder.
eheheeh this is the problem. I can't find it on my minix android box.[/align]
FOUND!
/sdcard/Android/data/hk.minix.xbmc/files/.xbmc/addons/skin.aeonmq7/
(need to show hidden files to see it)
is possible to set kodi show hidden folder and file?
(2016-10-13, 19:49)mtguido Wrote: [ -> ]FOUND!
There's option in kodi settings to show hidden folder files.
