Full Version: CEC Adapter Settings Cancel Button not working
Hello,
cross-post from: https://discourse.osmc.tv/t/cec-adapter-...king/12797
I noticed, that under Settings/System/Input devices/Peripherals/CEC Adapter the "Cancel"-Button does not work.
Expected behavior: Any Changes made are discarded.
Actual behavior: Any Changes made are saved.
Could someone please verify, if that also apply to Kodi running on a Raspberry with CEC (not OSMC).
I don't know, if that's a Kodi or OSMC issue.
PS: I used the latest Kodi stable (16.1) with OSMC on RP3 for testing.
Best regards
Casper
I have the same issue in Kodi 17 beta 3 on my RP3.
(2016-10-20, 19:57)casperklein Wrote: [ -> ]I noticed, that under Settings/System/Input devices/Peripherals/CEC Adapter the "Cancel"-Button does not work.
On a RP3, with latest Milhouse bulds (Kodi 17 beta 4) with CEC (conected to Panasonic TV), "Cancel" button works as expected, any changes made are discarded, after reboot.
Well, I did some more testing, and the result is: any changes made in CEC configuration and then pressing Cancel button, does not brig up message "CEC Configuration Updated", but made changes will stay active untill PI3 is rebooted. After reboot all changes not saved, but canceled, are lost and CEC settings revert to those before making any change.
Thank you both for the feedback. I've created a bug report (http://trac.kodi.tv/ticket/17007).
