2016-10-21, 23:41
2016-10-24, 20:38
I'm guessing no, as the profile determines what databases to use.
Could be wrong though...
2016-10-24, 20:41
And maybe enabling some kind of guest user?
By now i have one guest profile and kodi log in automatically to it, and then i load my profile from settings, but i can have only one private profile because all should know master user password to load their profile
2016-10-24, 20:45
what's the end result you are looking for?
2016-10-26, 00:32
I want it to be headless, so i need to be able to controll it before loading any profile, and obviously i need more than one profile.
2016-10-27, 21:11
wondering why you need profiles on a headless unit.. I guess you are updating 2 different databases on this Pi using some automation?
Maybe you can script it by using list_of_built-in_functions (wiki)
Load the specified profile. If prompt is not specified, and a password would be required for the requested profile, this command will silently fail. If promp' is specified and a password is required, a password dialog will be shown.
Runs Kodi in master mode
LoadProfile(profilename,[prompt])
Mastermode
2016-10-27, 22:12
Can you add one example of LoadProfile usage, i've been trying for a while and i can't make it work (never asks for passwords or load any profile)
2016-10-27, 23:10
Have a look at this post for some examples of how to send commands to the JSON RPC
http://forum.kodi.tv/showthread.php?tid=...pid2418722
2016-10-31, 00:44
Thanks now i have it working properly
2016-10-31, 01:21
good stuff!
