hello im using a pi2 that has and sd card in it with kodi on it i wanted to know if i use another sd card and put retropi onto it and just switch out the two different cards that i want to use. the install goes onto card not the pi correct? so it wont be overwriting anything? any information would be great
Sent from my SM-G900V
Correct. The Pi has no onboard storage, everything goes onto the SD card.
ok great so i can use two different cards
also can i hook up my ps3 controller to the pi2? idk if it has bluetooth compatibility or i need a Bluetooth dongal.
The R-Pi2 does not come standard with bluetooth. If you are running RetroPie on the same board, I recommend upgrading to the R-Pi3, as it clocks in more processing power.
I hope this helps you out.
thanks i got a usb controller lastnight and hooked it up it works great. but i noticed that u run roms off of usb stick dont that make it any slower then just installing them on pi sdcard?
