Hi
Is it possible download a copy of version 1225 or does anyone have a copy they could let me have? The download link seems to be broken.
I've been seeing live TV freeze and sometime crash since going to the latest versions. I'm keen to test if it's the version change or something else on my network.
It would be more helpful if you could post the serverwmc log after a crash or freeze. Or better yet, try installing the preview version 1239 and see if that solves the problem.
But you can download 1225 from here, if that's what you prefer:
https://github.com/ServerWMC/serverwmc.g...C-1225.zip
Great, thanks
I tried the preview when I started to see issues and that's where I'm currently seeing the issues. I'll try to get the logs before I look at reverting to the old version
Didn't have to wait very long for it to freeze. But the latest entry in my log file appears to be from 2013!
2013/10/22 20:01:56.628 OnClosing> shutting down Worker
2013/10/22 20:01:56.629 WorkerClose> closing client socket
2013/10/22 20:01:56.630 WorkerClose> closing any running streams
2013/10/22 20:01:56.631 WorkerClose> stopping maintenance timer
2013/10/22 20:01:56.631 WorkerClose> stopping RecServce/EPG
2013/10/22 20:01:56.633 RecordToWTV::Close> RecorderUse is Passive: False
2013/10/22 20:01:56.909 ListMissingGenres> Total count of genre look-ups: 847
2013/10/22 20:01:56.909 ListMissingGenres> No missing genres found
2013/10/22 20:01:57.305 TV Objectstore closed
2013/10/22 20:01:57.306 CloseTraceLog: -- exited normally
Are you running it as a service?
No, set to start with windows
Any idea why the log file has that date?
The machine has been running since before 2013 but is an i7 and should be up to the job. I've only been using serverwmc for last 18 months for my main machines since giving up WMC and moving to kodi but I've had serverwmc installed since before 2013 so it's possible the log stopped writing 2013.
I'll fully remove and reinstall unless you have any other ideas.
Hi
I reinstalled version 1225 which has got the log file working correctly. However i'm still seeing network timeout issues in the client. I've experienced lots of issues this evening from 8pm. The last being at 9.21-22. I'd be very grateful if you could tell me if the log file gives any pointers to the issue
http://pastebin.com/DaDLwfpR
