2016-10-23, 22:36
Hi all.
I have a PI3 running Raspbian OS with Pixel. I've made an update and upgrade of the OS.
After that, I've installed kodi using the ppa of pipplware.
For setup I was using a big monitor and everything went fine. Run kodi and done the proper setup.
Disconnected everything and connect an 7 inch LCD from Wave share; I ssh into PI, change the config.txt by adding the lines below:
I open PI, image on the Waveshare LCD looking fine; touch is working if I connect mouse is working also. The LCD is connected to USB port of PI.
Then, I start kodi and all I get is a black screen. I ssh into it, reboot - everything looks fine, I start kodi again - black screen.
After some research on the net I find this post "http://forum.kodi.tv/showthread.php?tid=241622&page=2" where an idea about powering the LCD screen directly - not via PI USB is given. So, I power the LCD directly, reboot, desktop shows fine . . ..but I have no touch working;
I start kodi, and everything is OK, I can make setup, go check the menus, play moovie, everything OK - but only with the mouse attached to USB of PI, so I have no touch in kodi and no touch also in the OS. The only possible access to menu and stuff is via mouse connected.
Next, I shut down, connect USB of Pi to USB of LCD screen, HDMI to HDMI, start . . . .and now the touch function is back; I start kodi, program is running, I manage to use the touch for 2-3 seconds but after that the screen goes blinking and showing different lines like in this post " http://forum.kodi.tv/showthread.php?tid=241622&page=3" - user DaniiSahne; exactly like this, after 20-30 seconds the kodi menu shows back again, able to use the touch for a while and then again a lined screen - and the story goes forever.
So is anyone able to tell me what is wrong and how to fix it?
reason is I want to test PI3+LCD as a carputer in the near future, so having touch available when using kodi is mandatory . . .
max_usb_current=1
hdmi_group=2
hdmi_mode=1
hdmi_mode=87
hdmi_cvt 1024 600 60 6 0 0 0
