----- Window Deinit (DialogConfirm.xml) ------
22:29:41.714 T:140566384846848 DEBUG: CAddonMgr: enabled pvr.vdr.vnsi
22:29:41.714 T:140564791404288 DEBUG: Thread JobWorker start, auto delete: true
22:29:41.725 T:140566384846848 DEBUG: CGUIMediaWindow::GetDirectory (addons://user/xbmc.pvrclient)
22:29:41.725 T:140566384846848 DEBUG: ParentPath = [addons://user/xbmc.pvrclient]
22:29:41.744 T:140564791404288 DEBUG: CAddonMgr::GetAvailableUpdates took 13 ms
22:29:41.747 T:140564774618880 DEBUG: Thread BackgroundLoader start, auto delete: false
22:29:41.749 T:140564774618880 DEBUG: Thread BackgroundLoader 140564774618880 terminating
22:29:41.749 T:140566384846848 DEBUG: CGUIMediaWindow::GetDirectory (addons://user/xbmc.pvrclient)
22:29:41.750 T:140566384846848 DEBUG: ParentPath = [addons://user/xbmc.pvrclient]
22:29:41.767 T:140564791404288 DEBUG: CAddonMgr::GetAvailableUpdates took 12 ms
22:29:41.769 T:140564774618880 DEBUG: Thread BackgroundLoader start, auto delete: false
22:29:41.770 T:140564774618880 DEBUG: Thread BackgroundLoader 140564774618880 terminating
22:29:42.681 T:140566384846848 DEBUG: LIRC: Update - NEW at 4945370:160 0 KEY_OK devinput (KEY_OK)
22:29:42.681 T:140566384846848 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select
22:29:42.692 T:140566384846848 DEBUG: PVR - Create - creating PVR add-on instance 'VDR VNSI Client'
22:29:42.692 T:140566384846848 DEBUG: ADDON: Dll Initializing - VDR VNSI Client
22:29:42.692 T:140566384846848 ERROR: ADDON: Could not locate pvr.vdr.vnsi.so.2.6.9
22:29:42.692 T:140566384846848 ERROR: UpdateAddons - failed to create add-on VDR VNSI Client, status = 6
22:29:42.692 T:140566384846848 DEBUG: ------ Window Init (DialogConfirm.xml) ------
22:29:43.683 T:140566384846848 DEBUG: LIRC: Update - NEW at 4946372:160 0 KEY_OK devinput (KEY_OK)
22:29:43.683 T:140566384846848 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select
22:29:43.886 T:140566384846848 DEBUG: ------ Window Deinit (DialogConfirm.xml) ------
22:29:43.918 T:140566384846848 DEBUG: CAddonMgr: enabled pvr.vdr.vnsi
22:29:43.918 T:140564774618880 DEBUG: Thread JobWorker start, auto delete: true
22:29:43.926 T:140566384846848 DEBUG: CGUIMediaWindow::GetDirectory (addons://user/xbmc.pvrclient)
22:29:43.926 T:140566384846848 DEBUG: ParentPath = [addons://user/xbmc.pvrclient]
22:29:43.946 T:140564791404288 DEBUG: CAddonMgr::GetAvailableUpdates took 14 ms
22:29:43.948 T:140564473276160 DEBUG: Thread BackgroundLoader start, auto delete: false
22:29:43.949 T:140564473276160 DEBUG: Thread BackgroundLoader 140564473276160 terminating
22:29:43.951 T:140566384846848 DEBUG: CGUIMediaWindow::GetDirectory (addons://user/xbmc.pvrclient)
22:29:43.951 T:140566384846848 DEBUG: ParentPath = [addons://user/xbmc.pvrclient]
22:29:43.969 T:140564791404288 DEBUG: CAddonMgr::GetAvailableUpdates took 13 ms
22:29:43.971 T:140564473276160 DEBUG: Thread BackgroundLoader start, auto delete: false
22:29:43.972 T:140564473276160 DEBUG: Thread BackgroundLoader 140564473276160 terminating
22:29:44.541 T:140566384846848 DEBUG: LIRC: Update - NEW at 4947230:160 0 KEY_OK devinput (KEY_OK)
22:29:44.541 T:140566384846848 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select
22:29:44.552 T:140566384846848 DEBUG: PVR - Create - creating PVR add-on instance 'VDR VNSI Client'
22:29:44.552 T:140566384846848 DEBUG: ADDON: Dll Initializing - VDR VNSI Client
22:29:44.552 T:140566384846848 ERROR: ADDON: Could not locate pvr.vdr.vnsi.so.2.6.9
22:29:44.552 T:140566384846848 ERROR: UpdateAddons - failed to create add-on VDR VNSI Client, status = 6
22:29:44.552 T:140566384846848 DEBUG: ------ Window Init (DialogConfirm.xml) ------
22:29:45.463 T:140566384846848 DEBUG: LIRC: Update - NEW at 4948152:160 0 KEY_OK devinput (KEY_OK)
22:29:45.463 T:140566384846848 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select
22:29:45.666 T:140566384846848 DEBUG: ------ Window Deinit (DialogConfirm.xml) ------
22:29:45.693 T:140566384846848 DEBUG: CAddonMgr: enabled pvr.vdr.vnsi
22:29:45.705 T:140566384846848 DEBUG: CGUIMediaWindow::GetDirectory (addons://user/xbmc.pvrclient)
22:29:45.705 T:140566384846848 DEBUG: ParentPath = [addons://user/xbmc.pvrclient]
22:29:45.724 T:140564774618880 DEBUG: CAddonMgr::GetAvailableUpdates took 13 ms
22:29:45.727 T:140564473276160 DEBUG: Thread BackgroundLoader start, auto delete: false
22:29:45.728 T:140564473276160 DEBUG: Thread BackgroundLoader 140564473276160 terminating
22:29:45.729 T:140566384846848 DEBUG: CGUIMediaWindow::GetDirectory (addons://user/xbmc.pvrclient)
22:29:45.729 T:140566384846848 DEBUG: ParentPath = [addons://user/xbmc.pvrclient]
22:29:45.747 T:140564791404288 DEBUG: CAddonMgr::GetAvailableUpdates took 13 ms
22:29:45.750 T:140564473276160 DEBUG: Thread BackgroundLoader start, auto delete: false
22:29:45.751 T:140564473276160 DEBUG: Thread BackgroundLoader 140564473276160 terminating
22:29:46.341 T:140566384846848 DEBUG: LIRC: Update - NEW at 4949031:160 0 KEY_OK devinput (KEY_OK)
22:29:46.341 T:140566384846848 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select
22:29:46.359 T:140566384846848 DEBUG: PVR - Create - creating PVR add-on instance 'VDR VNSI Client'
22:29:46.359 T:140566384846848 DEBUG: ADDON: Dll Initializing - VDR VNSI Client
22:29:46.359 T:140566384846848 ERROR: ADDON: Could not locate pvr.vdr.vnsi.so.2.6.9
22:29:46.359 T:140566384846848 ERROR: UpdateAddons - failed to create add-on VDR VNSI Client, status = 6
22:29:46.359 T:140566384846848 DEBUG: ------ Window Init (DialogConfirm.xml) ------
22:29:47.243 T:140566384846848 DEBUG: LIRC: Update - NEW at 4949932:160 0 KEY_OK devinput (KEY_OK)
22:29:47.243 T:140566384846848 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select
22:29:47.446 T:140566384846848 DEBUG: ------ Window Deinit (DialogConfirm.xml) ------
22:29:47.476 T:140566384846848 DEBUG: CAddonMgr: enabled pvr.vdr.vnsi
22:29:47.485 T:140566384846848 DEBUG: CGUIMediaWindow::GetDirectory (addons://user/xbmc.pvrclient)
22:29:47.485 T:140566384846848 DEBUG: ParentPath = [addons://user/xbmc.pvrclient]
22:29:47.502 T:140564774618880 DEBUG: CAddonMgr::GetAvailableUpdates took 13 ms
22:29:47.505 T:140564473276160 DEBUG: Thread BackgroundLoader start, auto delete: false
22:29:47.506 T:140564473276160 DEBUG: Thread BackgroundLoader 140564473276160 terminating
22:29:47.507 T:140566384846848 DEBUG: CGUIMediaWindow::GetDirectory (addons://user/xbmc.pvrclient)
22:29:47.507 T:140566384846848 DEBUG: ParentPath = [addons://user/xbmc.pvrclient]
22:29:47.524 T:140564791404288 DEBUG: CAddonMgr::GetAvailableUpdates took 12 ms
22:29:47.526 T:140564473276160 DEBUG: Thread BackgroundLoader start, auto delete: false
22:29:47.527 T:140564473276160 DEBUG: Thread BackgroundLoader 140564473276160 terminating
22:29:48.161 T:140566384846848 DEBUG: LIRC: Update - NEW at 4950850:160 0 KEY_OK devinput (KEY_OK)
22:29:48.161 T:140566384846848 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select
22:29:48.171 T:140566384846848 DEBUG: PVR - Create - creating PVR add-on instance 'VDR VNSI Client'
22:29:48.171 T:140566384846848 DEBUG: ADDON: Dll Initializing - VDR VNSI Client
22:29:48.171 T:140566384846848 ERROR: ADDON: Could not locate pvr.vdr.vnsi.so.2.6.9
22:29:48.171 T:140566384846848 ERROR: UpdateAddons - failed to create add-on VDR VNSI Client, status = 6
22:29:48.171 T:140566384846848 DEBUG: ------ Window Init (DialogConfirm.xml) ------
22:29:49.183 T:140566384846848 DEBUG: LIRC: Update - NEW at 4951872:160 0 KEY_OK devinput (KEY_OK)
22:29:49.183 T:140566384846848 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select
22:29:49.386 T:140566384846848 DEBUG: ------ Window Deinit (DialogConfirm.xml) ------
22:29:49.413 T:140566384846848 DEBUG: CAddonMgr: enabled pvr.vdr.vnsi
22:29:49.425 T:140566384846848 DEBUG: CGUIMediaWindow::GetDirectory (addons://user/xbmc.pvrclient)
22:29:49.425 T:140566384846848 DEBUG: ParentPath = [addons://user/xbmc.pvrclient]
22:29:49.444 T:140564774618880 DEBUG: CAddonMgr::GetAvailableUpdates took 14 ms
22:29:49.446 T:140564473276160 DEBUG: Thread BackgroundLoader start, auto delete: false
22:29:49.447 T:140564473276160 DEBUG: Thread BackgroundLoader 140564473276160 terminating
22:29:49.449 T:140566384846848 DEBUG: CGUIMediaWindow::GetDirectory (addons://user/xbmc.pvrclient)
22:29:49.449 T:140566384846848 DEBUG: ParentPath = [addons://user/xbmc.pvrclient]
22:29:49.467 T:140564791404288 DEBUG: CAddonMgr::GetAvailableUpdates took 13 ms
22:29:49.469 T:140564473276160 DEBUG: Thread BackgroundLoader start, auto delete: false
22:29:49.470 T:140564473276160 DEBUG: Thread BackgroundLoader 140564473276160 terminating
22:29:50.501 T:140566384846848 DEBUG: LIRC: Update - NEW at 4953190:160 0 KEY_OK devinput (KEY_OK)
22:29:50.501 T:140566384846848 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select
22:29:50.513 T:140566384846848 DEBUG: PVR - Create - creating PVR add-on instance 'VDR VNSI Client'
22:29:50.513 T:140566384846848 DEBUG: ADDON: Dll Initializing - VDR VNSI Client
22:29:50.513 T:140566384846848 ERROR: ADDON: Could not locate pvr.vdr.vnsi.so.2.6.9
22:29:50.513 T:140566384846848 ERROR: UpdateAddons - failed to create add-on VDR VNSI Client, status = 6
