Full Version: Kodi 17 beta 4 (and nightlies since) - Windows 10 - all DSP Modules Fail to load
excerpt of log with error (only show one module but all DSP modules fail in same way)
http://pastebin.com/YLFCc4eZ
basically the error is:
ERROR: ADDON: Dll Audio DSP Basic Processor - Client returned bad status (6) from Create and is not usable
interestingly I get the same error for the input stream modules and the joystick module as well.
Before beta 4 things at least loaded and worked for the most part
Can I provide you with any other info, files, etc?
Thanks,
Mario
Thx for reporting. It should be fixed soon. It was an issue related to most binary add-ons.
