Full Version: Intermittent Missing LiveTV Icon When Using ServerWMC /w Silicon Dust
I've been using this setup and it's worked great for years, thanks for all the time and effort put in! Now, I'm not certain what has changed but the the live TV icon in the main menu of Kodi is no longer showing up, and it's intermittent on my other kodi client. If I restart kodi enough times, it will eventually pop up. Any help in finding out why this is intermittently starting and not working on my main kodi box is greatly appreciated.
Non working Host: capt.home.runlevelone.lan
Working Host: blackwidow.home.runlevelone.lan
Linux/Distro: Fedora 24
Kodi Version: kodi-16.1-2.fc24.x86_64
PVR Version: kodi-pvr-wmc-16.1-5.fc24.x86_64
Kodi Theme: Titan
Kodi Logs: https://paste.fedoraproject.org/461399/
ServerWMC Logs: https://paste.fedoraproject.org/461401/
Thanks again.
For what its worth (not much) there is no problem in the serverwmc log. I'm no help with the kodi log, but there are definitely errors there. Have you tried reinstalling kodi?
It's next on the list, but no, not yet, hoping for something a little more definitive before redo'ing my kodi configuration. Definitely plan on doing it before football on Sunday. Wink
In the Kodi log you posted either it's incomplete or PVR never gets a chance to startup because of other errors. It looks like something in "Skin Helper Service" is failing toget artwork for some audio library stuff
specifically it mentions this file is not well formed (maybe try deleting that)? Or try removing/disabling any addons youve got that are related to that?
profile/addon_data/script.skin.helper.service/musicartcache/A Wilhelm Scream.xml
