If so, I can't find it in skin settings. My Exit sub-menu has Favourites in it which seems incongruous since accessing Favourites suggests that you want to stick around for a while.
How instead would I add the Favourites menu to a different shortcut, eg Movies?
Thank you.
OK, I found this from half a decade ago:
"Hello Mike - to remove the buttons from the home screen you would need to edit the Home.xml in the 720p folder. To remove the favourites and suspend buttons from the shutdown menu you would need to edit the DialogButtonMenu.xml in the PAL19x9 folder."
That's not a safe route for me to go down so I'll just leave it where it incongruously wants to be. But I would like to additionally append the Favourites menu to the Movies shortcut - if possible without editing code.
