Full Version: Avoid scraping nfo for every episode?
Hi there,
I really like EMM, its very helpful for me, but there is one little thing that annoys me.I want EMM only scrap nfo for the TV-Show itself (tvshow.nfo), not for every single episode I have (that should Kodi to), but I can not figured out how to set this up!?
Would be great if someone can point me to the right direction.
Thanks in advance.
Try going into settings->TV Shows->Naming and choose expert tab, set everything up the way you would like. When you get to episode naming, do not fill in the .nfo part. Not sure if that will work, but worth a shot.
Thank you, but sadly I already did that.
Here is how my File-Naming Settings look:
I'm assuming you have all other naming schemes unchecked? Sorry, thought that might have worked for ya!
Yes, every other box (Kodi, Kodi Addons...) are unchecked, expect Expert.
No problem, I appreciate every hint and tip, so thank you for your help Smile
Edit:
Update to the latest Alpha seems to solved my problem Smile
