Full Version: Visualisation stops after several songs
Hello!
I am using kodi 17 beta 5 (linux), and any viz always stops after 4 or 5 songs played.
Kodi continues to play, but without viz.
This problem does not seem to occur with a kodi version without the patch to correct the problem with different soundcards...
Do you have the same problem?
which kodi version are you talking about?
Kodi (17.0-BETA5 Git:2016-10-29-e5cb8b0-dirty). Platform: Linux x86 64-bit
(2016-11-04, 11:24)amand Wrote: [ -> ]This problem does not seem to occur with a kodi version without the patch to correct the problem with different soundcards...
you say you use a patched kodi, which patch(es)? Where did you get them from?
Sorry for this late reply.
With the previous git version (kodi 17 b1), the viz does not stopped.
The problem occurs with the beta5. The beta5 contains a correction made in the git, for a problem with different soundcard (you can take a look at this thread : 290740 (thread)).
please post in that thread, together with a Debug Log
