Hello,
I would like the "Play from here" option when selecting TV shows. That way I can play the selected and all subsequent episodes from the selected tv show episode.
See screenshots below:
1. How it works on KODI.
2. How I would like it to work on iOS KODI Remote
Thank you.
It's feasable, I'll look into it. Question: if play from here is triggered from an episode inside a certain season number, usually only the remaining episodes from that season are included or even the episodes for the later seasons? (if any)
I guess the remaining episodes from the current season will do. However it works when used directly from KODI should be good.
Thank you.
