# Use Xft?
use_xft=yes
xftfont Monospace
ize=7
xftalpha 0.8
text_buffer_size 2048
# Update interval in seconds
update_interval 1
# This is the number of times Conky will update before quitting.
# Set to zero to run forever.
total_run_times 0
# Create own window instead of using desktop (required in nautilus)
own_window yes
own_window_transparent yes
own_window_type desktop
own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
# Use double buffering (reduces flicker, may not work for everyone)
double_buffer yes
# Minimum size of text area
#minimum_size 200 0
minimum_size 200 200
maximum_width 240
# Draw shades?
draw_shades no
# Draw outlines?
draw_outline no
# Draw borders around text
draw_borders no
# Stippled borders?
stippled_borders 0
# border margins
#border_margin 5
# border width
border_width 1
# Default colors and also border colors
default_color grey
#default_shade_color black
#default_outline_color white
own_window_colour 333333
# Text alignment, other possible values are commented
#alignment top_left
alignment top_right
#alignment bottom_left
#alignment bottom_right
# Gap between borders of screen and text
# same thing as passing -x at command line
#gap_x 30
gap_x 12
gap_y 60
# Subtract file system buffers from used memory?
no_buffers yes
# set to yes if you want all text to be in uppercase
uppercase no
# number of cpu samples to average
# set to 1 to disable averaging
cpu_avg_samples 2
# number of net samples to average
net_avg_samples 2
# Force UTF8? note that UTF8 support required XFT
override_utf8_locale yes
# Add spaces to keep things from moving about? This only affects certain objects.
use_spacer none
TEXT
kernel
| + ${nodename} ${kernel}
Time
| + ${time %H:%M} ${time %d %b %Y}
System
| + CPU: ${cpu cpu0}%
| + RAM: $memperc%
+ Temp: ${acpitemp}ÂșC
| + /: ${fs_free /root}/${fs_size /root}
| + /var: ${fs_free /var}/${fs_size /var}
| + ~/: ${fs_free /home}/${fs_size /home}
Net
| + Up: ${upspeed wlan0}kb/s (${totalup wlan0})
| + Down: ${downspeed wlan0}kb/s (${totaldown wlan0})
Processes
| + NAME $alignr PID CPU
| + ${top name 1} $alignr ${top pid 1} ${top cpu 1}
| + ${top name 2} $alignr ${top pid 2} ${top cpu 2}
| + ${top name 3} $alignr ${top pid 3} ${top cpu 3}
| + ${top name 4} $alignr ${top pid 4} ${top cpu 4}
| + ${top name 5} $alignr ${top pid 5} ${top cpu 5}
